Re: Custom West-Coast Design Feedback
We're not quite done deciding, but we really liked how the west coast robots performed at the events we were at. We have fairly good machining resources, so it seemed like a logical step up from our KoP drive this year. As for my design, after what I have seen in this thread, I have gone supports crazy. I grossly overestimated the amount of structural elements I need, as well as the fact that steel may be way overboard. I'm working on a new design that will feature aluminum. Are there any other changes you could reccomend? Thanks, daliberator Last edited by daliberator : 11-06-2014 at 12:04. Reason: Forgot a sentance |
I personally have never built a WCD base only designed a few in Inventor. Some of the reasons teams jump to do a WCD is because its easy to change out a wheel and if you use bearings blocks you have integrated chain spacing which were two features that stuck out to our team a lot after last year. In the end we opted over building a WCD to try new products/techniques while improving performance. For instance we used solid rubber Colson wheels for our drive wheels and found a C-C chain spacing calculator from team 1640 to calculate the space between each wheel to eliminate chain tensioners (we used #35 chain). These two decisions allowed us to never touch the base and accomplished our two main reasons for looking at a WCD which is why we haven't made one. Our base was really easy to make and it built off of what we were comfortable with. Its just always good to discuss why you intend to build something compared to doing something that a majority of high performing teams do just because they do it. Yes their WCDs are very, very good drivebases but their drivers are what really make them shine and that goes for every team. WCDs aren't very popular up here in New England but we do have our share of extremely good base drivers that can compete with the best. Most notably, team 195 the Cyberknights driver destroys the playing field to be honest. He is very in tune with the match play and more importantly how his robot best moves on the field. He does all this with just a modified kitbot. They swapped the front wheels for omnis and upgraded the gearboxes to 3 CIM single speeds and he uses them to the full potential which is something a lot of teams overlook. I use 195 as one of the many examples we have up here but a little goes a long way. If its performance you are looking for make some small mechanical tweaks but really give your driver that time to practice especially in the offseason. That is what makes good drivebases. ![]() |
Having 1/8" of drop is pretty standard, +/- how much sponginess your tread will have. 3/16" should be ok for most drivetrains, although I don't know what tread you are using.
A rule of thumb I've always followed is 1/8" for flat wheels (ie colsons, kit wheels, etc), and 5/32" or 3/16" for blue nitrile. The properties of the blue nitrile tread allow for even the slightest amount of contact to affect turning, and because they grip the carpet so well the increased drop is sometimes needed to ensure there is no contact.
We ran 1/8" drop this year on Colsons and that was probably too much. I'd rather have gone 1/16". |
#10
Did you cut tread into your colsons?
#11
We left them untreaded for one event and cut treads in them for our second event. Turned great both times but was a bit rockier than I wanted. Perhaps that's just the tradeoff one has to make.
Back in 2011, 1/8" was just right for a long base with Colsons. |
#12
For clarification - was it rocky both times because of the drop, or was it rocky after you cut the treads? Also, did the treads affect the smoothness of the wheel's ride (did driving feel more bumpy)?
#13
2013: 6 wheel WCD with two speed 4 CIM custom shifters geared for 9/19 fps before frictional losses. The wheels were 6inch custom 3d printed and if memory serves they were 1 inch wide. The robot frame was 30"x24", dont rember wheel spacing exactly but it was ~11 inches give or take. Here's a CAD render of it. 2014: 6 wheel WCD with two 3 CIM Ballshifters geared to 6/16 fps before losses. The wheels were the 4 inch AM performance wheels and the frame was 23.5"x32" with about 8" between wheels. We almost went with no drop on this but decided to go with a very slight drop to be safe. Wheel also almost made it a four wheel WCD but decided against it. Here's a render of the robot. |
#14
2363 over the past year used a 1/4" holed lexan (the holes were put there in the manufacturing). It was easier for the team to use that for wiring and with weight. In 2013, we used garalite, but found it too fragile and would shatter easily.
