Go to Post Only on CD would people debate calculus problems involving time and team numbers... - artdutra04 [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 15-06-2014, 18:14
Andrew Lawrence
Posts: n/a
Colson CAD folder - available for all
I've been collecting some CAD models for commonly used Colson wheels since they've been becoming popular in FRC and the CAD is pretty difficult to get a hold of, and I've decided to share my collection: https://drive.google.com/folderview?id=0BxNpey1R08BIZlNwYVpMeW9CWW8&usp=sha ring
Wheels I have so far:
3" x 1.5" Performa grey tread
4" x .875" Performa grey tread
4" x 1.25" Performa grey tread
4" x 1.5" Performa grey tread
4" x 2" Performa grey tread
The 3" x 1.5", 4" x 1.5", and the 4" x 2" are all compatible with the WCP Colson hubs. The rest need to bored out to a 1 3/16" bore, but since it's a common size it shouldn't be too difficult if you have the resources. For the shorter ones you may need to shave the hub down a bit, but it'll still work fine. As for the 4" x 2" wheel, the hub will be slightly short, but it will still support the wheel just fine.
If you have requests for wheel types and sizes to get, I'd be more than happy to work on finding an appropriate CAD file for the wheel.
Hope this is useful!
Unread 15-06-2014, 19:17
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
Rookie Year: 2010
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
Re: Colson CAD folder - available for all
Thanks for posting these, they sure beat the disks I have been using as placeholders!
2015 Midwest Regional Finalists (Thanks to 2338 and 1756)
2014 Central Illinois Regional Finalists (Thanks to 4143 and 2039)
2013 Curie Division Semifinalists (Thanks to 2056 and 3990)
2013 North Star Regional Champions (Thanks to 2175 and 4607)
2011 10,000 Lakes Regional Champions (Thanks to 525 and 3642)
Unread 15-06-2014, 20:57
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Oh, thank you so much! CAD for Colson wheels are so hard to find.
Would you know where to find a cad file for the 3.5", 2.5" and 2" wheels? I used those in a couple designs but wasn't sure if the dimensions were correct.
Unread 15-06-2014, 21:06
Andrew Lawrence
Posts: n/a
Give me wheel widths for each and I can get them all for you when I get back home. It's a long process I'm starting to automate to make easier.
Unread 15-06-2014, 21:56
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
What is that process? Are you generating models based on dimensioned drawings that you found somewhere?
Thanks for the models.
Unread 15-06-2014, 21:59
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Thank you for putting the work into this! It really is a pain to track them down, so I (and I'm sure many others) really appreciate you putting this folder together!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 15-06-2014, 22:09
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
Thanks so much for doing this! Very useful indeed.
As someone else posted, are there dimensioned drawings you found somewhere, or are you taking the dimensions off of purchased wheels or something of the sort? You mentioned automating the process - I'm not exactly sure how you're doing it, but I know there's a feature in Solidworks known as design tables. There may be something similar in Inventor (if you're using it) you could look at using to help aid the process?
Edit: I'm not sure why I thought you were using Inventor.
Unread 15-06-2014, 22:16
Andrew Lawrence
Posts: n/a
It involves finding a real-life product that uses a caster that used that specific wheel, finding CAD for said product, and extracting the wheel CAD.
Unread 15-06-2014, 22:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I've pulled models from the Colson Caster Website without any issue.
Unread 15-06-2014, 23:14
Andrew Lawrence
Posts: n/a
I tried that and the system would keep crashing.
Unread 16-06-2014, 01:32
Carrington's Avatar
Carrington Carrington is offline
AKA: Carrington
FRC #1625 (Winnovation)
Carrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant futureCarrington has a brilliant future
You must create an account in order to download the 3D models. It's a free and easy process that give you access to pretty much every colson model you would ever need in a variety of file formats. After you have created an account simply select a wheel and you will see an option to "Create 3D Model" in the lower left corner. The Create 3D Model button itself is actually just a button to update the model based off the properties of the caster you have selected so if you hit that button it will seem like nothing is happening when in reality it is updating the model you are looking to download. For FRC purposes this is usually not very useful outside of selecting wheel size considering you are most likely going to delete most features except for the wheel itself. You want to use the download section which is directly below the Create 3D Model button. From there you select the file format and hit the download button which will create the file for you to download.
Unread 16-06-2014, 01:40
Andrew Lawrence
Posts: n/a
Originally Posted by Carrington View Post
You must create an account in order to download the 3D models. It's a free and easy process that give you access to pretty much every colson model you would ever need in a variety of file formats. After you have created an account simply select a wheel and you will see an option to "Create 3D Model" in the lower left corner. From there you select the file format and hit the download button which will create the file for you to download.
I have an account - I looked into it when I read Sanddrag's post and found I had a funky version of java. Uninstalled and installed again and now it works fine.
Unread 16-06-2014, 01:51
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Thank you for these models. I'm using them in the butterfly drive I'm designing.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-06-2014, 02:53
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
http://www.robotmarketplace.com/prod...W-BPDWC05.html 3 x 1.5"
http://www.robotmarketplace.com/prod...W-BPDWC03.html 2.5 x 1.5"
http://www.robotmarketplace.com/prod...W-BPDWC02.html 2 x 0.875"
  #15   Spotlight this post!
Unread 16-06-2014, 22:31
Andrew Lawrence
Posts: n/a
3 x 1.5" was already in the folder.
2.5 x 1.25" added.
2 x .875" added.
