Go to Post Dont give up, because that is when you lose what you have. FIRST is the best experience that I have had throughout my entire life and there is no way ANYONE can make me quit FIRST. - Arefin Bari [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 18-06-2014, 12:18
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: pic: Plywood Butterfly Drive Render
Originally Posted by AllenGregoryIV View Post
The biggest issue with this is it makes it harder to do your reductions.
It's not too hard with the central gearbox design since you can do a second reduction with the belts to the modules. From JVN's calculator, a 12:60 reduction in the gearbox and a 24:42 reduction with the belts gives adjusted speeds of 6.4fps on the Colson wheels and 12.9 fps on the omni wheels.
Originally Posted by Joe G. View Post
Have you considered using pancake cylinders for module actuation to save some space and weight?
I'll look into doing that.
I noticed a few problems with my design that I also need to fix in the next iteration: the belts to the modules run into the bellypan, the bolt that serves as an axle for the gearbox is not adequately supported and the bottom two CIMs in each gearbox can't be installed or removed once the chassis is assembled.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 20-06-2014, 00:14
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
It's great to see another team going with this method of construction. Mine has been doing laser cut plywood chassis in the past two years, and we love it.
