Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
  #46   Spotlight this post!
Unread 25-06-2014, 11:44
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Re: Limiting Drivetrain Motors
Originally Posted by JamesCH95 View Post
I won't disagree that F1 lap times have been improved primarily by suspension and handling, but it doesn't negate the parallel. If motor availability (engine displacement) is reduced then teams will find other ways to make their robots (cars) just as fast as they were, like multi-speed automatic transmissions (improvements in suspension, brakes, and tires). This fits in nicely with your point - the restriction won't slow down the higher-end teams who can devote resources to making more advanced transmissions (develop suspension, tires, brakes) but it will hurt middle and bottom tier teams who do not have the resources to devote to these efforts.
Since F1 was brought up and totally unrelated to the op's topic, lap times have been dropping primarily due to advances in aerodynamic efficiency. This is why the FIA has been increasing limitations on the size/extent of aero surfaces on F1 race cars.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
  #47   Spotlight this post!
Unread 27-06-2014, 05:12
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Originally Posted by FrankJ View Post
Or you could just mount the main switch on a good heat sink & put a fan on it?
Can you do that? That seems kind of cheap...
At that point, you might as well tack on another few pounds to add in a whole high power LED cooling system.
