Go to Post There is a very fine line between passion and emotion, sometime it gets crossed. Let's not confuse the two. - JohnBoucher [more]
Unread 27-06-2014, 08:02
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
pic: Frog Force 503 Leapfrog Drivetrain
Unread 27-06-2014, 08:04
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: pic: Frog Force 503 Leapfrog Drivetrain
Very nice.
How do you maintain chain tension when raising or lowering the outside wheel?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 27-06-2014, 10:36
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Originally Posted by z_beeblebrox View Post
Very nice.
Assuming that the chain shares the same axle that the module pivots on, In theory it should have the same tension in both positions. This is because it's moving on an arc with a constant radius so the distance between the wheel and the pivot point never change.
Thats my understanding of it anyways. Please do correct me if I'm wrong.
Unread 27-06-2014, 14:48
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Rookie Year: 2013
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Could we have a closer look at the gearboxes?
Unread 27-06-2014, 18:52
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Seems unlikely, since the chain runs between two wheels, neither of which is on the module pivot. I'm guessing the arc that the omni follows closely approximates a circular arc that maintains chain length. Since the omni doesn't have to move very far, I'm thinking this can be close enough (though I haven't run any numbers).
I believe they are these.
Unread 28-06-2014, 08:11
FF TSL: Frog Farce
The chain run will lose .07 inches of length when in the up position, if this becomes an issue, we will add a spring tensioner to it. The gearboxes are a slightly modified version of the earlier posted one, the final version is at http://frcdesigns.com/designs-gearbox/
Unread 30-06-2014, 17:57
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Way back when we ran an articulating drivetrain in 2011, we designed it so that the chain length was identical in the up and down position but it got a bit of slack while moving. We deemed this to be acceptable and never had any issues.
Kettering Motorsports
Unread 30-06-2014, 20:57
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
Rookie Year: 2010
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
This is the same way my teams octocanum works. It rotates in the opposite direction as the way you have your module and only untensions for a brief amount of time. As long as the sprockets are aligned it won't fail (unless you use it for 10 demos without maintenance over the summer and break the chain itself).
