Go to Post It is impossible to be grumpy about anything when eating biscotti made by one's beautiful wife, drinking tea sweetened by one's own honey, warmed by a wood stove, and with a dog asleep on one's foot. Simply impossible. - pfreivald [more]
Unread 30-06-2014, 10:15
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Swerve Concept
Hi I have been working on this design with a mentor on my team, its getting pretty close and thought id see what you guys think.
Some of the gears I realized after endearing were not mated properly. I fixed them so don't worry.
I have a few questions as well, what do you think the best way to hold the gears in place is? also, what do you think of the design overall?
If you are confused just ask, whenever i show this to someone they are usually confused.
ID:	17137  Click image for larger version
ID:	17138  Click image for larger version
Unread 30-06-2014, 10:38
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Re: Swerve Concept
Are you asking how to hold the crown gears in the module in place? or the spur gears between the motors.
When we did our car/crab drive in lunacy and breakaway we used one single brass pillow block to hold both crown gears and support the axles. of course, it looks like the large crown gear shares an axle with the wheel here, where ours had another stage lower down
For the spur gears (depending on live/dead axle) there is hardly any axial load (gravity isn't much) if you can machine groves for E-clips they would work just fine. Shaft collars (especially the thin and light VexPro ones) would work as well
EDIT: looking back at the pictures, PVC or Delrin (or anything really) spacers would hold the spur gears
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 30-06-2014, 11:15
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Re: Swerve Concept
What are you using for your bearings between the rotating module and the frame?
Also, if this were to be made, how would you make the .125" sheet metal part? Getting that to line up nicely for a gearbox is easier said than done.
As others have said, the normal gears and their shafts can be held in place with snap rings or spacers. It is also useful to turn down the end of the 1/2" hex shaft to 1/2" round and use a round bearing to keep the shaft from sliding out. The bevel gears will have thrust loads, which are along the axis of the shaft so it's important to be aware of this in your design. Team 1640 uses a thrust bearing probably similar to this one http://www.mcmaster.com/#6655k13/=smu6aw
I've also seen teams get away with using a thrust washer similar to this one
http://www.mcmaster.com/#5906k411/=smu6ry
Where do you plan on purchasing the bevel gears from? Also, where does the wheel go?
Unread 30-06-2014, 11:23
jimbo493's Avatar
Quasi Mentor
AKA: Jimmy
Rookie Year: 2011
Re: Swerve Concept
We will have 2 wheels on either side of the bottom gearbox with the bevel gears.
The module will be cut and bent at a laser cut place near our build space.
The bearings for rotation is a big thrust bearing on the part in the upper gearbox, and a beveled bearing(I think thats what its called, mcmastercarr isn't loading for whatever reason ATM). EDIT: its a roller bearing
Im not sure where we got the bebe gears from, we don't meet until the 7th, but ill ask then
Unread 30-06-2014, 12:21
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Rookie Year: 2013
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Re: Swerve Concept
Why do you want wheels on each side? What reduction are you using for the BAG motor to pivot them?
Also what are the flanged plates made of? 0.125" aluminum?
Unread 30-06-2014, 13:15
jimbo493's Avatar
Quasi Mentor
AKA: Jimmy
Rookie Year: 2011
Re: Swerve Concept
2 Wheels allow for more traction and less stress on the bevel gears, plus its just helps with overall stability, we are using the new 4in vex wheels
We will probably use .125 in
Unread 30-06-2014, 13:59
FRC Alumnus
FRC #1768
Rookie Year: 2013
Re: Swerve Concept
This one?
Well keep in mind that, while more wheels will keep the tread pattern from wearing down as quickly, doubling the number of wheels will give only a very minor improvement in traction since, while it is simplified, friction very closely equals N*mu. Having a wheel on each side will significantly increase the torque required for pivoting and it will probably take a minimum of a quarter of a second or so to rotate a module 180 degrees.
Unread 30-06-2014, 14:26
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
Re: Swerve Concept
Originally Posted by Greg Woelki View Post
This one?
Well keep in mind that, while more wheels will keep the tread pattern fromthe wearing down as quickly, doubling the number of wheels will give only a very minor improvement in traction since, while it is simplified, friction very closely equals N*mu. Having a wheel on each side will significantly increase the torque required for pivoting and it will probably take a minimum of a quarter of a second or so to rotate a module 180 degrees.
On a deformable surface like carpet, the n mu approximation isn't a valid assumption, he'd pretty much need to test it himself with his wheel setup in order to figure out how friction would be effected. With a rough top tread I would think you would get more friction, but probably not with a smooth vex wheel, but this is just a guess. The increase in turning torque is correct though and if more surface area was beneficial I'd just have a single thicker wheel to take advantage of the low torque required to turn near the axis of rotation.
Also, getting the holes on the two 1/8th inch pieces of aluminium to line up is going to be very challenging, I would recommend making it out of a single piece of extrusion or two flat plates with standoffs.
Last edited by Bryce Paputa : 30-06-2014 at 14:35. Reason: Added fabrication warning
Unread 30-06-2014, 14:39
FRC Alumnus
FRC #1768
Rookie Year: 2013
Re: Swerve Concept
Do you know of any quantitative data that teams have collected about this with different wheels/treads? I have been unable to find any.
Unread 30-06-2014, 14:49
FF TSL: Frog Farce
Re: Swerve Concept
Nope. Vex has some CoF's listed, but they say nothing about the testing method or how it's related to surface area. Later this summer I plan on doing a test to determine this with different wheels and to figure out which gives the best traction, but this probably won't be for a while.
Unread 30-06-2014, 15:55
jimbo493's Avatar
Quasi Mentor
AKA: Jimmy
Rookie Year: 2011
Re: Swerve Concept
We will see how accurate our vendor is, we may have to do standoffs, we'll see
As for the wheels, you bring up a good point, the 2 wheels will add a lot of friction. I don't foresee that it will be too much of an issue.
I think the best thing we can do is build one module like it is, then we'll have to tweak it quite a bit. What i like about it is at the form factor, its very small, and its all gear driven with no belts or chains which means less chance of things breaking.
Thinking about it more, It would also be pretty difficult to make this design with a single wheel. I still think we will have enough torque to turn the wheel with adequate speed. There really is only one way to find out..to test it.
Unread 30-06-2014, 16:02
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Rookie Year: 2011
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: Swerve Concept
Some things to think about. Weight of a swerve drive is often very heavy trying to reduce the weight is a major chore.
Just to keep in mind. The closer your gears are to the final reduction of the drive train the more or a moment they will be taking. This can be come a huge problem when you take large amounts of pushing or something unexpected. The moment is directly related to your wheel size.
Also remember your whole robots weight will be carried through the upper gear box this can cause major problems for thin metal flexing and losing gear spacing causing them to skip/bind I like belts for this reason. The competition is not the most ex-stream things that will happen some one might drop it and one of the poor modules will take the load of a potently 150 pound robot falling from 2 feet. I like belts for this reason.
My team has been designing a swerve drive using the same duel wheel concept.
http://imgur.com/a/H6Qcm
The main goal over the old was was to reduce the size/ machining complexity/assembly complexity/points of failure/ and the biggest was increasing mechanical efficiency.
Unread 30-06-2014, 15:49
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Swerve Concept
This one?
Dangerous statement here. I agree with everything you said EXCEPT the claim of .25 seconds to go 180*. That speed would actually be pretty quick for most swerves people are currently running.
Unread 30-06-2014, 15:59
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Swerve Concept
2 wheels doesn't inherently equal more traction. It would result in pretty much the same stress on the bevel gear as well - how do you figure that it would result in less?
Please don't guess.
The edge case I know about that seems to affect pushing force based on wheel width is roughtop tread on 4" wheels. I remember reading data somewhere (but not experimenting myself, something to do in the fall) which showed a negligible difference in traction for 6" and 8" wheels of different widths as well as wedgetop tread. Specifically 4" roughtop tread wheels have noticeably better traction in a 2" wide configuration as opposed to 1" wide.
I have never seen any data on Colson wheels or Vex wheels with regard to width versus traction. Based on purely subjective experience, I think people are somewhat overstating the benefits of a wider wheel in terms of carpet traction. We would have to do testing to be sure though, perhaps in the fall.
Yes, definitely a factor here. Your turning torque is a function of the size of your moment arm when spinning the wheel, so the farther from the center the tread is in contact with the ground the greater the torque needed to turn the module.
Alternately they could leave the bends in, with a bit more clearance away from each other, and use standoffs to actually hold the plates together to ensure alignment. This keeps the rigidity benefits of the bends.
OP: Have you thought about how to mount this to a frame? A popular idea on the west coast is to make a 2x1 frame and mount the gearbox to each side of the 2x1, using the existing frame as a big spacer. Also, what are your gear ratios?
Not at all, you can easily do some math to get an approximation of how much torque it takes to turn a wheel and whether or not your system has enough reduction to do so.
  #15   Spotlight this post!
Unread 30-06-2014, 16:01
FRC Alumnus
FRC #1768
Rookie Year: 2013
Re: Swerve Concept
It would be advisable to go further on the speed side of the motor curve than one would be with the reduction that I used in my calculation, hence a minimum of a quarter of a second. I suppose that half a second would be more reasonable in this set up.
