Re: Swerve Concept
The two wheels spaced far apart will take substantially more torque to turn, there is no way they will get BETTER performance than current optimized narrow centered wheel swerves. |
Re: Swerve Concept
I estimated that around 80in*lbs would be needed to turn that two-wheel module. A BAG motor has a stall torque of 3.5in*lbs, so, while more reduction would be better, I went with 100:1 in my calculation. Free speed of a BAG motor is 14000 rpm, so 140rpm with the reduction and 108rpm under the load. That works out to 0.56 seconds per rotation, or a bit over 0.25 seconds for 180 degrees. So, while it may take more torque to pivot and while one may want to run the motor further on the speed side of its curve, that is where I got my numbers. Last edited by Greg Woelki : 30-06-2014 at 16:31. |
Re: Swerve Concept
Re: Swerve Concept
I was about to ask this.
Re: Swerve Concept
You wouldn't, that was just my picturing of the module rotating, not really applicable.
Re: Swerve Concept
We will to calibrate the steering, but only then
Re: Swerve Concept
For reference, last year we used Bag motors with 90:1 versa planetary gearboxes (10x3x3) for steering with no issues. We had no further reduction after the Versas.
Re: Swerve Concept
If you don't want to switch the direction of your drive motor, like team 118 did in 2008.
Re: Swerve Concept
A swerve control algorithm can always run the drive motors one direction and check to see which way to turn. Least distance. Or the algorithm can look for the shortest distance with motor reversal. Both will work. We have done the latter. This does put a stress mechanical and electrically on the module. The first has increased response times. Now say you have a CVT solution for swerve, but the response is asymmetric on the direction of the drive motors. Works really good counter clockwise, terrible clockwise shaft end. Do you accept greater than 90 degree steering solutions for CVT or is the steering response more important? That's what I've asked our team.
#10
Re: Swerve Concept
We opted to go with the force gauge test because we felt it was safer, easier and more accurate than the ramp test (the cart tended to fall forward off the ramp before it slipped) *not new, slight wear. |
