Go to Post One team at the UTC regional scored over 2100 points in autonomous alone. I was highly impressed. - Greg Marra [more]
Unread 02-07-2014, 00:44
Fluffy21 Fluffy21 is offline
FRC #0702
Fluffy21 is an unknown quantity at this point
Unable to deploy code to cRIO
Hi! So my team recently decided that we would like to switch to Java from C++, and we are having a bit of trouble. I have some code ready to be sent the cRIO, but I cannot deploy it as I usually get two types of errors. One is that the build.xml messes up on lines 79 and 41 (will double check on that). After that error I usually cancel the build and try again and it goes through and then proceeds to get stuck on disable().... consider using your own (will update once I have the exact phrase.
Also I do have an established connection with my cRIO. I am able to ping it as well as FTP the IP address to access it. The firewall is disabled and I allowed netbeans to use an incoming and outgoing connections as it desires. I have tried this on two different laptops to no avail. Please help!
