Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 07-04-2014, 02:00 AM
Tiernoez Tiernoez is offline
FRC #1072 (Harker Robotics)
Rookie Year: 2014
Tiernoez is an unknown quantity at this point
Adding a custom library to Robot Code? (Java)
Hello all,
So we've written a library containing some basic items that we've used from year to year. However, I'm stuck trying to figure out how to add it to the actual robot code. I don't want to add all of the files into the project itself, but, unlike with vanilla NetBeans projects, the robot project doesn't have the feature to add libraries. Could anyone give any suggestions as to how to go about doing so?Thanks so much!
Unread 07-06-2014, 03:27 PM
Nxmq99 Nxmq99 is offline
AKA: Nico Machado
FRC #4322 (Clockwork Oranges)
Rookie Year: 2014
Nxmq99 is an unknown quantity at this point
If you bundle it with the wpilibj source, you should be able to compile it and set it as the wpilibj file for your robot in the settings within net beans.
Unread 07-06-2014, 07:06 PM
jamestautges jamestautges is offline
FRC #1306 (Badgerbots)
Rookie Year: 2012
jamestautges is an unknown quantity at this point
Re: Adding a custom library to Robot Code? (Java)
Go into the build.xml file and add something along the lines of the following code:
Code:
<exec executable="rm">
    <arg value="-rf" />
    <arg value="/path/to/robot/project/src/LibraryName" />
</exec>
<exec executable="cp">
    <arg value="-R" />
    <arg value="/path/to/library/src/org" />
    <arg value="src/" />
</exec>
This copies the library to the robot project's src directory which makes it available during the build. The rm makes sure that the directory is updated every build, in case the library has changed. If you're using windows, you'll have to change the command names, but this should work on any Unix system.
Unread 07-07-2014, 02:35 AM
Rookie Year: 2014
Thanks this is exactly what I needed!
Unread 07-14-2014, 10:26 PM
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Rookie Year: 2012
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Remember that you'd need to post it publicly before build season for it to be used legally - that one almost got us this year. Good luck!
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 07-15-2014, 07:44 AM
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
Rookie Year: 2012
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
If you can, I'd recommend using GitHub -- not only does it solve the releasing part (as you'd be open-sourcing it), but if you use Git during the year, you learn valuable skills widely used in industry.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
