Go to Post If that track ball comes crashing into Exploding Bacon's robot there is literally going to be an Oink Oink BOOM!:yikes: - Koko Ed [more]
Unread 04-07-2014, 19:10
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
Rookie Year: 2013
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Remote cRIO code deploying
Has anyone ever attempted to set up a cRIO to receive code remotely? For example, to wire it up to a router at your team's workshop and upload code from a team member's house. I was wondering if it could be done while programming a socket client on the cRIO to connect to the NVIDIA Jetson TK1 dev board. My idea is to get vision processing done on the Jetson and send the results over to the cRIO (and eventually roboRIO) via sockets.
Cheers!
P.S. Is there any way of running a thread on the cRIO to constantly update the value from the socket input stream in the background?
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
Unread 04-07-2014, 20:10
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Re: Remote cRIO code deploying
It's possible to receive code remotely, but only if you can set up port forwarding at your work space. All the netbeans deploy script does is build your code, FTP the built files to the cRIO, then tell the cRIO to restart itself.
As for the network communication, yes it is possible to have a separate thread. If you're using Java, I'd use a TimerTask. You can create a class which extends TimerTask, create a new java.util.Timer object, then call timer.scheduleAtFixedRate(this, 0, period), where period is the time (in ms) between each iteration.
Unread 05-07-2014, 03:50
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Place a RasPi, running PPTPd. Log into the PPTPd. You're entire computer will be forwarded onto the robotics network. Then, you won't be able to just program the robot, but also be able to drive it and view camera footage, etc.
