Go to Post This year's rules != last year's rules. - GaryVoshol [more]
Unread 05-07-2014, 21:06
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
pic: 8-Wheel Chassis
Unread 05-07-2014, 21:08
evanperryg's Avatar
AKA: Evan Grove
Rookie Year: 2011
Re: pic: 8-Wheel Chassis
Starting the discussion thread for suggestions. Here's the STEP file: https://drive.google.com/file/d/0B4P...it?usp=sharing
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 05-07-2014, 21:38
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Rookie Year: 2011
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
I am exstreamly interested in the octagon frame, and what design decisions did you use to come up with it what advantages do you think it will give you?
Why the 8 sides with such steep corners?
Unread 05-07-2014, 21:43
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Looks good!
I would not set up the wheel axle bearings the way you have them now. I would definitely use some type of bearing block so that the bearing is well supported. Right now, all the load on the shaft is concentrated on only .125" of the bearing.
Unread 05-07-2014, 21:56
evanperryg's Avatar
AKA: Evan Grove
Rookie Year: 2011
My team used a similar octagon frame this year, with 4.5" sides on a 45deg angle. These corners are 5" long in a 3-4-5 triangle arrangement. Although this makes for some weird angles, it means that all of the side lengths are whole, rational values (in other words, less math ). Octagon frames have a few advantages:
-It allows you to have more inside surface area while staying inside a 112" perimeter.
-Defensive robots can't hit your corners. This doesn't sound like much, but any robot with omnis as outside wheels can easily be bumped out of position by a corner push.
Yeah, a bearing block would be used. The bearings in the model are just there to say that a bearing goes in that general area.
2013
2015
Unread 06-07-2014, 01:16
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Hey I just noticed something
The dimensions are 28"x32", which makes a 120" perimeter. If the rules remain as the last two seasons, you can only have 112" if this were for competition
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 06-07-2014, 01:23
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
Rookie Year: 2011
Remember by having the corners be diagonal like that you can keep within the 112" rules.
Unread 06-07-2014, 01:24
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
It would probably be helpful to read the post directly above yours, which explains how the chamfered corners allow within frame perimeter.
1310 did the same thing in 2013.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
