Thread Tools |
Rating:
Display Modes |
Re: pic: 4587-Sheet Metal Chassis V.2
This frame is quite beefy but keep in mind that the sharper the corners the higher the stress concentrations.
Seen here: http://prntscr.com/40gv2q |
https://www.flickr.com/photos/robowr...7642758521834/ |
Triangular pocketing is far more optimal (unless too much is taken out) than circular. If an equal amount of weight is removed the triangular pattern is stronger unless it's laid out awful. |
Nice! Looks like a solid design, and like you got all the tricky bits right.
I'd put some material back in the front and back of the frame. Those parts take a beating... You can drop some of the material on the top of the frame, and on the rails holding the wheels. The frame itself will be strong enough, and the holes make it easy to inspect your robot for wear. Point impact loads from other robots and field elements should be your biggest loads. You can take the inner frame rails down to 060 as well. Reinforce the bearing holes when you do that. Consider lightening the belly pan, and adding PEM nuts in for your electronics. Those small touches take a design to the next level. |
FHS Press in studs CLS Press in nuts SO Threaded standoff LAC Floating self locking threaded insert PL Nylon Locking nut F Flush nut Prototype Kit |
