Go to Post Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about! - Andrew Blair [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 10-07-2014, 21:37
MCeGEAR MCeGEAR is offline
FRC #1243
MCeGEAR is an unknown quantity at this point
Python Multi Processing
Hello All,
I need some help with multi-processing in python on the bot. I would use multi threading but because of the global lock in CPython that isn't doable, or at least that is what i assume is what is blocking its use i could be just completely wrong and miss using the threading.
None-the-less, here is a class i wrote up to get rate from a infinite turn pot hooked up to a roller, it works as long as it is ran fast enough, other wise it will miss a turn or two and give out some funky data, it isn't very clean and doesn't work on the bot because of no multi-threading support.
If i could get some help it would be great, I would prefer to get multi-processing working, but if i could have it run under a timed event properly instead that would be fine as well.
Thank you all very much the code is below, feel free to take and use or re-write it any way you feel.
Code:
class potRate():
    def __init__(self, potObj, timerObj):
        self.rate = 0.0
        self.stopThread = False
        self.lastRate = 0.0
        self.lastPotVal = potObj.GetVoltage()
        self.potObj = potObj
        self.timerObj = timerObj
        self.timerObj.Start()
        self.timerObj.Reset()
    def calcValue(self):
        while not self.stopThread:
            try:
                #This tells us how much it has traveled since it was last looked at by comparing last to current
                Rate = 0.0
                lastRate = self.rate
                potVal = self.potObj.GetVoltage()
                potDiff = (self.potObj.GetVoltage() - self.lastPotVal)
                #The pots give some jumpy data so this is a very basic filter that seprates out any garbage in readings
                if (abs(potDiff) >= 0.02):
                    #here we actually calulate out the rate, rate is just distance travled over time, we time how fast the pot moved
                    #Becuase of the way the shooter works, we don't want negitive values
                    if (potDiff > 0):
                        Rate = potDiff/self.timerObj.Get()
                        Rate = (Rate + lastRate)/2
                    else:
                        pass
            except ZeroDivisionError:
                Rate = 0.0
                print("RPM error zero divison")
            except:
                print("RPM error unhaneled")
                self.stopThread = True
            self.rate = Rate
            self.lastPotVal = potVal
    def Start(self):
        self.rateThread = threading.Thread(target=self.calcValue, args = ())
        self.rateThread.daemon = True
        self.rateThread.start()
    def Stop(self):
        self.rateThread.join()
    def getRate(self):
        return self.rate
