Go to Post We're not disappointed if we don't achieve excellence, so long as we did everything we could in our pursuit of it. - JVN [more]
Unread 13-07-2014, 02:10
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
Rookie Year: 2013
zinthorne will become famous soon enough
6 wheel vs. 8 wheel WCD
I am wondering, what are the differences/pros and cons between a 6 wheel WCD and 8 wheel WCD. A 6 wheel WCD is lighter, an 8 wheel probably has more traction, but is there anything else?
Unread 13-07-2014, 02:18
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: 6 wheel vs. 8 wheel WCD
6WDs are prone to rocking due to their dropped center wheel (barring other arrangements like omnis or odd CG arrangements). 8WDs are much less prone to rocking because both center wheels are dropped.
The "more traction" argument is one that will depend heavily on the specific drive systems involved. I suspect that some 6WDs have more traction than some 8WDs, as well as the other way around. Think about it this way: The same weight is being spread across more points of contact with the ground, reducing the normal force. OTOH, that's also more points where power can be applied and frictional effects that appear to raise the CoF can happen. The only way to make that claim definitively is to do a full analysis of two systems that are identical other than number of wheels (and associated power transmission).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 13-07-2014, 02:20
bkahl's Avatar
bkahl bkahl is online now
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Rookie Year: 2013
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
In an 8 wheel drive, the center four wheels are usually dropped, so there is always a stable platform. In a 6 wheel drive, the center two wheels are dropped making the robot rock sometimes. Many teams chose the 8 wheel drive design this year so the rocking didn't reduce the accuracy of a shot.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 13-07-2014, 02:29
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I forgot one other difference. It wasn't an issue the last couple of years, but it has been in the past, and that is traversing obstacles.
A 6WD will generally need somewhat more ground clearance than an 8WD to cross the same obstacle. This is because there is more space in between the wheels to get a "high-center", where the obstacle hits the frame and stops progress. Those aren't exactly fun to get out of, and often need a hit from a partner.
Past teams:
Unread 13-07-2014, 10:00
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Of course, this difference was hardly noticeable on the flat field we've had the last two years But it is a good point, if you go back and watch matches from 2010, almost everyone who could efficiently get over the bumps was an 8-wheel drive with some considerable clearance. (also note that I only know of one mecanum drivetrain that could get over the bumps in 2010.)
On a flat field, 6 and 8 wheel drives are almost exactly the same. 8 wheel drives do have the advantage when you look at the details, but the main difference between the two will be the quality of the driver.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 13-07-2014, 10:10
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
We ran a 6 wheel drive in 2010 and 2012 and got over both bumps just fine.
Unread 13-07-2014, 10:12
evanperryg's Avatar
AKA: Evan Grove
Rookie Year: 2011
Alright, I guess I should clarify: 8 wheel drives need less clearance to get over the same obstacle. In 2010, there were plenty of 6 wheel drives that could do it, but 8 wheel bases didn't need as large of a ground clearance.
2013
2015
Unread 13-07-2014, 14:51
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Bomb Squad's swerve drive (4 wheel) didn't seem to have any problem getting over the bumps in 2012. Our kitbox 4 wheel drive didn't have a issue in 2010. That was with one motor per side. As said earlier, it is about ground clearance & design.
Calculating which drive system has the most friction is difficult. You have to have a model of the wheel carpet interface. Classical friction theory says they are all the same, but that model really doesn't apply completely. If you are running a drop center scheme you mostly have traction on just 4 wheels at a time. Welcome to the difference between science & engineering.
Unread 13-07-2014, 16:00
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Rookie Year: 1999
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
A well balanced 6wd will have better turning response/handling than a 8WD because it will have minimal wheel scrub forces on the outer wheels (due to there being very little weight on them). We find this to be a huge advantage and really helps with having an amazingly driven robot.
6wd also have fewer parts, which helps with weight and manufacturing.
Unread 13-07-2014, 16:04
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Rookie Year: 2011
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
We've found this is the case too. Our recent 6wd have performed much better than out tests with 8wd.
