| Thread Tools |
Rating:
Display Modes |
Team 3489 Category 5 Presents Storm Drive
Hello CD Community,
Inspired by a trip to CMP in 2013 and the chance to spend time with the nice folks over at FRC Team 148 (Robowranglers), and the innovative gearboxes from FRC Team 192 (Gunn Robotics), we were inspired to push our creative envelope a little bit and come up with our own version of Butterfly Drive. Attached here is a representation of our competition "Storm Drive" from our 2014 entry, "Floyd Scaryweather". It utilizes a COTS worm gearbox with a 10:1 reduction, and HTD Timing belts driving 6 inch Omni wheels, along with a set of pneumatically actuated drop-down traction wheels with a 2.1:1 reduction. The theoretical top speed is 14ft/sec in high speed, and 6.7ft/sec in traction mode. With the fully enclosed gearbox and belt drive, the robot is eerily quiet. The gearbox utilizes a 3-start worm, and can be pushed (not easily) after a break-in period. The main goal of this design was to utilize the space between the frame rails in a way that the center of the chassis could be largely open. Our results were largely positive. The main issue encountered was with ratcheting encountered during a quick change of direction. We attempted to control acceleration/deceleration through software, but we're unsure if it was effective. We didn't encounter a lot of pushing matches in competition, but the low speed operation seemed to work as intended. Future iterations would likely include larger pulleys for greater engagement, closer c-c distances (0.5mm "slop" seems to be too much) or possibly converting from 9 to 15mm wide belts. So, please ask and comment away! |
Re: Team 3489 Category 5 Presents Storm Drive
Wow. This is really cool. Do you have any video of it in action?
I know what I want for Christmas
Why are the traction wheels more inside than the omnis? Having the traction wheels on the outside would provide more stability.
How much does a module weigh?
Wouldn't this depend on what you plan on having for your primary drive wheels?
Exactly, We use an orientation similar to this. It works well.
Basically, there's design benefits to having your traction wheels on the outside. I can't come up with any obvious ones to having your omnis on the outside. |
The problem with having traction wheels on the inside is that if your getting pushed its not uncommon to be tipped onto the outer omni wheels negating the effect of the traction wheels.
#11
If you are using small cylinders for actuation the air use is minimal. Add another tank. To me the benefit of knowing that I physically CANNOT turn under my own power far outweighs the downsides of adding a half pound of air tank. |
#12
The designer needs to identify what they are trying to gain by having two separate sets of wheels and make decisions accordingly. , Bryan Last edited by BJC : 28-07-2014 at 17:23. |
#13
I should be able to dig some up tomorrow.
#14
Yes, having the traction wheels outboard would improve stability. It's just a compromise. Having them inboard allows both ends of the axle to be supported, and reduces the torsional moment on the traction wheel assembly. It also allows some semblance of turning in the traction mode. Mostly, it's about packaging as most of the goodies are contained inside a 3inch wide channel.
#15
I haven't weighed an individual module, but our entire chassis, including all wiring and controls, sans battery and bumpers weighed in at 61lbs.
