Go to Post How about instead of using the flag we just all wrap out robots in color saran wrap. there! problem sovled! - John Gutmann [more]
Unread 29-07-2014, 22:51
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
1" Bore Timing Pulleys
Does anyone have a source for a 1" diameter timing pulley? I'm flexible on HTD, GT2, GT3, etc. I just checked the usual suspects and nobody seems to have one. We're working on a swerve drive project and were hoping to use one to rotate the steering tube with.
SDP-SI - no
B&B - no
McMaster - no
Martin Sprocket - no aluminum bushings
Quality Transmission Components - out of business
Gates appear to be the only game in town. I've never purchased anything through them outside of their KOP vouchers. From what I gather, all their pulleys are machineable and you have to add the bore yourself, which is doable but less desirable.
Anybody have any insight on where to get these, preferrably as a COTS item ready to use out of the box? If via Gates, do they work directly with teams or do you go through a local distributor?
Unread 29-07-2014, 22:56
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: 1" Bore Timing Pulleys
It's not likely that you'll find a 1" bore on a metric sized pulley. That being said, you may be able to find a 25mm bore pulley, which can be opened up (25.4 mm = 1") for your needs.
If you don't have machining resources, you could likely sand down the steering tube by hand. It's only .014" difference, assuming you can get the 25mm bore pulleys
Unread 29-07-2014, 23:03
craigboez's Avatar
Mechanical Engineer
There are plenty of inch bore options available for all the sources, but I can't find anything above 0.75". 25mm would be fine, we could work with that, but I can't find anything that large.
Unread 30-07-2014, 00:23
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Using a lathe, you can just buy pulley stock and make your own 1in bore pulleys. For example #A 6A24M024TM20 from SDP-SI is 24t 5mm HTD aluminum pulley stock. From this you drill in the ID of your choice and then wafer off individual pulleys with a parting tool.
If you go this route, always try to design around sprockets with a multiple-of-three number of teeth; this way it'll be much easier to clamp the pulley stock into a 3-jaw chuck since the soft jaws will all align to the same phase of the pulleyteeth.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 30-07-2014, 03:06
craigboez's Avatar
Mechanical Engineer
You make this sound fairly easy. Working with pulley stock has always looked like a lot of hassle to me. We have a G0602 bench top lathe, so I think this would be tricky for us to handle in house. Are there any other tips to working with these? And what is the intention of the shank that comes as part of the pulley stock?
Unread 30-07-2014, 03:44
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Rookie Year: 2011
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Its not very hard to open a pully up. Just something to make sure of though is that when you try to bore out a plastic pulley with a aluminum center it will generate a huge amount of heat if done wrong potently slipping the plastic around the metal. This could really hurt the operator. We ran in to some problems on our swerve; lost a boring head...
Also make sure the aluminum core has the room for a one inch bore.
In the end we went with a solid aluminum pulley for the steering.
The 1640 history with the development of there swerve is a great tool for this type of thing.
We could not find a cots pulley that was with in a reasonable price with the bore at 1"
Unread 30-07-2014, 06:37
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
We use HTD5 all AL pulleys and then bore them out on the lathe. Plastic pulleys we have found do not have the clearance to drill out with a key way. We found it better to drill in several steps from 1/2" to 1". Our HTD pulley supplier got out of the business and we are looking for a new supplier. Lead time can be a problem.
Unread 30-07-2014, 16:44
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Team Role: Mechanical
Rookie Year: 2007
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
I'm making the assumption that because you are making a swerve, you have some sort of CNC milling ability. When we made ours, we bought pulley stock, cut it on the band saw, faced it, and drilled a small center whole in the lathe. Then we put it in the mill, and put the zero on the small whole with a center finder. We then ran a program that lightened the pulley and opened the 1" bore.
It's a bit of a long process, but we only have a table top lathe as well.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 30-07-2014, 16:48
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
For 5mm pitch and above pulleys it's actually a big enough tooth to comfortably cut on a mill.
So for a pulley where you might be doing a lot of machining. Pocketing, mounting holes, custom bore, etc... it's actually easier for a shop to make the entire pulley (versus precisely zeroing on existing geometry).
We found a 2.5mm cutter is about the biggest cutter you can fit in 5mm pitch teeth. The OD of the pulley was roughed with a fairly large cutter, the teeth were roughed with a 3/16 or 5/32 and then finished with the 2.5mm. It wasn't crazy runtime, a few minutes per pulley iirc.
Unread 30-07-2014, 17:41
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Rookie Year: 2007
That's a fair point, and if we trusted ourselves using a bit that small at the time we cut our pulleys, that's probably what we would have done. Some What against our best judgment, the swerve that we built this year, was one of the first things we had done with a CNC mill. The smallest bit we consistently trusted ourselves with was 0.25". It would have been nice to cut it ourselves thought, would have saved money and possibly time.
Unread 31-07-2014, 14:11
craigboez's Avatar
Mechanical Engineer
Gdeaver - I noticed in the 1640 CAD models that you guys chose a 32T, 5mm HTD x 15mm wide setup. Are you able to offer any details about how you arrived at this selection? I'm curious if it was a function of product availability, or if it was more based on torque requirements?
Unread 31-07-2014, 22:32
FRC #1640
Our choice of the 32t HTD5 pulley is part historical and torque requirements. Do not under estimate the abuse the steering components take. The 15 mm belts do stretch over the life of the robot and our key ways do loosen up. That's after a whole season with over a hundred hours of drive time. It sucks up enough of the build season with just boring the pulleys. I don't want to add the time to make them. If we could find a cots pulley I would buy it to save time. Custom pulleys add cost and lead time.
Unread 01-08-2014, 02:28
AdamHeard's Avatar
Lead Mentor
This certainly depends on the team and their specific resources.
We now have the resources in house, and at sponsors, to make a pulley with all the pocketing and mounting holes (for a bolt circle) we might desire out of solid stock in about 10 minutes of machine time (this includes a 2nd op on a manual lathe to face to thickness) per pulley, and at a lower material cost than purchasing pulleys. This reduces both cost and lead time (for us).
There are certainly many cases where COTS is the better option.
What's really key is constantly re-evaluating your own resources and best designing to match what you have (and also pushing to add resources to fill the holes you have).
Unread 01-08-2014, 10:14
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Do you mind sharing your process? I've played around with toolpaths for pulleys in MasterCAM, but we need a smaller than .125" endmill for the 5mm HTD profile. Do you put a circular feature in the center and broach a hex, or do you try to make the hex on the CNC (if you even use a hex at all)?
  #15   Spotlight this post!
Unread 01-08-2014, 13:35
AdamHeard's Avatar
Lead Mentor
We use a 2.5mm end mill for the teeth. (after roughing with larger end mills as described above).
We've run the hex both ways. Round then broach, or milled on the machine with the corners drilled out.
Let me know if you need more information.
