Re: 1" Bore Timing Pulleys
For those of you making your own pulleys, what CAD files are you using?
Cutting keyways, if needed, may be a little tricky but not awful. If broaches are not available you can use the lathe as a shaper. |
Opening up the bore on a pre-made pulley can be done on a manual mill relatively easily with a boring head. Just indicate the pulley bore, put the boring head in and bore it out to 1".
On a lathe the operation would be pretty similar, I would think, except you would not need to indicate. As a side note, swerve drives do not require CNC capabilities provided you are okay with a small amount of added weight (due to less pocketing). |
