Go to Post Are they Robots? Of course they aren't robots; they are obviously and unambiguously robots. - gblake [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 06-08-2014, 06:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Andymark Churros
Originally Posted by Chowmaster4695 View Post
http://www.chiefdelphi.com/forums/sh...0&postcount=16
You stated they would bend here. Please give us accurate information. Our students use chief delphi to help them make decisions where others have more experience. If they see contradictory posts like yours then they and many others will be confused. Please edit your post.
Chow Out
Excuse me. Please read the rest of my post:
"This might have been due to to other drivetriain problems that stopped us from moving too much though.
6063 is considerably weaker than 6061, so I would be wary of using it. For prototyping, it might be fine, but it would be much safer to just purchase some 1/2" 7075 hex stock from Online Metals instead."
Emphasis on my own post mine. If I could edit my post, I would, but I can't. I posted later in the thread to clarify this.
As a side note, please keep in mind that I am indeed a real person, and I have my own experiences, which might be different from yours. Different does not mean incorrect.
Now, to clarify my statement:
My team used some 6061 axles due to 7075 being unavailable late season. We experienced a multitude of drivetrain problems, leading to us only being able to move during half the matches. However, post-season while we were debugging the drivetrain, we discovered that axle bending was not one of the issues in our drivetrain. More likely it was due to incorrect tensioning of chain.
So, I can say this: 6061 is fine for axles, provided is is not under undue stress. It is cheap, which would be the main reason why you would use it. For a prototype drivetrain, it should work fine. However, once the season rolls around, switching 6061 for 7075 should not be a huge issue.
There have been threads in the past detailing shaft strength as compared to shaft diameter (for rounds). There is one here: http://www.chiefdelphi.com/forums/sh...t=38737&page=2
It would be wise to run some calculations, regardless of material being used. It's just plugging in a few numbers.
Originally Posted by Chris is me View Post
What's the point of building a prototype drive if you're not going to test durability? If you're building a drivetrain before the season starts, you should build as close to how you would in build season as you can. That way, if and when you do have failures, you can directly apply them to your future robot. If you use parts you know will fail to cut corners, you won't know if the part you intended to use in build will work properly.
Good point. I was thinking of just a proof-of-concept drivebase, but for a proven design like WCD you're right, it would be better to design realistically instead. Might be a good idea to have some 7075 on hand anyway then...
  #32   Spotlight this post!
Unread 08-08-2014, 10:50
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Originally Posted by AdamHeard View Post
It's worth noting that the 6063 that the Churros are made of has a substantially lower yield.
We have made a mistake on the AndyMark website, incorrectly stating the wrong alloy of aluminum for these extruded churros. They are actually made of 6005A aluminum.
As for using them on an FRC-sized drivetrain as a cantilevered axle, I would not recommend this, for many reasons stated previously in this thread.
Sorry for this error in stating the wrong alloy! The website is now corrected.
Sincerely,
Andy Baker
  #33   Spotlight this post!
Unread 08-11-2014, 13:26
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
FRC #2169 (KING TeC)
Rookie Year: 2012
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
Wow this thread got a lot of responses, thank you all for your input!
In regards to the material: After seeing that the churro extrusion was probably not going to hold up in a high stress environment like a drive train (thanks to all of the input from you guys), we researched the different alloys of solid hex stock we have available to purchase. Now Vexpro has issues with being out of stock right when we need something, so we opted for McMaster. We chose the high strength 2024 alloy hex shaft, and will be using this for our drivetrain project. This shaft had the highest yield strength of all the shaft available: 47,000 psi.
  #34   Spotlight this post!
Unread 08-11-2014, 15:18
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
C1018 steel yield is 54K and C12L14 steel yield is 70K if you need stronger. We've gotten some recommendations from local teams to look directly at tool steel for direct driven cantilevered wheels after this past seasons abuse to avoid bending.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
  #35   Spotlight this post!
Unread 08-11-2014, 16:31
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
You also have the option of using AndyMark 1/2 Hex that made from 7075, although not sure if it is -O, -T6, or something else.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #36   Spotlight this post!
Unread 08-11-2014, 17:52
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
I really can't think of why you would possibly need to use tool steel axles for anything in FRC. Online Metals has 7075 hex aluminum, which even 6 cim drivers like 254 use.
  #37   Spotlight this post!
Unread 08-11-2014, 18:05
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
All cantilevered wheel setups aren't the same. If you have the wheel far out from the bearings, and you're using a large diameter wheel (more torque needed to drive it), I might consider using something stronger than 7075.
  #38   Spotlight this post!
Unread 08-11-2014, 18:18
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
It would have to be an absolutely massive wheel (like 8") and cantalievered out 2" from the chassis bearings to have a factor of safety of 2, according to my calculator. And tool steel axles is still overkill. 4140 steel would be my next choie.
Interestingly, the cantaliever only slightly affects the factor of safety.
Of course, if they want to run something lie 24" wheels, then I could see tool steel being a valid choice. But before doing that I would just increase the axle diameter.
EDIT: Actually, is tool steel even capable of taking axle type loads? It might be too brittle.
  #39   Spotlight this post!
Unread 08-11-2014, 18:45
Team Role: Coach
Rookie Year: 2010
I know teams that used steel axles this year that had bending issues with aluminum and mild steel. Progression of materials landed them at tool steel. Calculators have issues with being based in theory. The problem with theory is that it doesn't always jive with reality.
Andrew Basse
  #40   Spotlight this post!
Unread 08-11-2014, 19:32
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
What setup were they running?
What type of tool steel, out of curiosity? Some steels are labeled as such, even if they aren't technically tool steels.
  #41   Spotlight this post!
Unread 08-11-2014, 19:58
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
There are many varieties. Tool steels become brittle due to their heat treatment. Of course the composition of various tool steels can cause the hardness to be different from each other pre-heat treat. I have only worked with D2 and it bends before heat treating.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
  #42   Spotlight this post!
Unread 08-11-2014, 22:16
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Originally Posted by hrench View Post
I also want to weigh-in on the 'build it and see if it breaks' philosphy that's being encouraged here.
That is NOT SCIENCE. What Science IS is using previous observation to determine what will happen deductively. The reason we engineers make books of statistics about materials and books of equations about stresses is because science works. If we design something that will work because we've used science, we've taught the kids the value of STEM.
if we design something with the guess that it might break or might not, then we didn't teach math, we didn't teach use of historical empirical statistics and instead we've taught 'trial and error.'
Not a good way to be an engineer.
Don't get me wrong, I was a 'farmboy' and stuff on a farm is most always pushed till it's about to break--or does. Seeing how stuff breaks is a great learning experience and I recommend it.
But engineering --doing the math--works better in the real world and I think that's what we're supposed to be teaching the kids.
As a senior in EET, I have to at least partially disagree.
More times than not, in EET at least, that IS how designs are implemented. Why? Because more times than not the math is, in practice, an ideal figure that is not as precise as one would like it to be. For example, this is why they still teach Smith charts in Electromagnetics classes (for those that don't know it's a graphical way of analyzing RF circuits), because while the modern math is easy given a good calculator (we used TI-86/89's), in reality, there are so many factors at play that the realistic accuracy is equivlent to using graphical methods.
Another example is with microcontrollers and DACs. While often times what the DAC is controlling (in my case, it was an VCO tuning an FM radio) can be modeled with an equation, in practice in a fair number of cases it works better to build the system and then through trial and error find the values needed. In my case, it was the 100 values corresponding to the 100 "channels" in the FM band. While, even with an optimized "scrolling" set of code to expidite the process, this took a couple of hours to find all the values (in the 12 bits the DAC would see), the result was a radio that despite being in an RF lab with poor reception, would pick up stations with reasonably clear sound. Using an equation to find the values probably would have worked, yes, but the results wouldn't have been as good.
Yes, math has a place, like initial designs (you have to stat somewhere), ballpark values (for situations that are hard to model), and feasibility analysis, but any good design is backed up with a tested and tuned prototype, which in some cases require some educated "guess and check" to get dialed in.
Relying on math alone may get a good grade on an exam but for actual design work, relying on math alone is a poor practice. To me, engineering is ultimately about good design work, not good test scores.
(yes, it's a long post, but I had something to say)
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
  #43   Spotlight this post!
Unread 08-11-2014, 22:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I am going to disagree, and agree. (I know, can't lose, right?)
Disagree: Sometimes, you have only one chance to get something right. Or for whatever reason, you don't have the resources to build a prototype and tune it prior to the final design. In such cases, it's actually a lot better to run the best numbers you have available--factoring in edge cases, outside factors. Relying on math in this case is actually good design work, primarily because there is minimal chance of actually being able to test your work. (There are a number of cases like this--think of large Civil Engineering projects, where you don't get X number of retakes. You just get a case of "OK, we found a problem, how do we fix it before we continue?")
Agree: For most cases, particularly high-volume production cases, it's usually a good idea to build a prototype or other test just to make sure that X will actually work. Even on those one-shot cases, your best math is actually going to come from scale testing, where you build a nice, cheap model and run it through various simulations to figure out exactly what's going on. For more complicated systems, a multitude of tests will be conducted.
tl;dr: Sometimes, the math just needs to be done, and done RIGHT, because no prototype will serve the purpose.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #44   Spotlight this post!
Unread 10-11-2014, 08:43
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Does your calculator include torsion? Or the combined stresses of bending and torsion? Do you make some allowance for the fatigue strength of aluminum?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #45   Spotlight this post!
Unread 10-11-2014, 10:12
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Like when you press the "fire" button on your lunar lander & hope it will take off and mate up with your command capsule somewhere in orbit?
If you don't know what you should hook up then you should read a data sheet
