Go to Post *wonders if omni wheel rollers come in MOE green or have to be dyed* - EricH [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 11-11-2014, 16:49
Oblarg Oblarg is online now
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Re: Andymark Churros
Originally Posted by hrench View Post
Simpler math that we can teach kids. So they can learn STEM, not trial and error.
Trial and error is a integral part of STEM, though. It's always worth considering to what degree the problem at hand is worth modeling, and to what degree you should just try stuff and see what works. Reality is a really good simulator .
We should certainly teach math when it is relevant and useful, but it is foolish to write off trail and error as "unscientific." After all, empiricism is pretty much the fundamental idea behind all of science.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
  #62   Spotlight this post!
Unread 11-11-2014, 23:39
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
Agreed! Sometimes my shop detail can mock-up a working part before my strategy team can prove their math!
Which goes back to FRC 4607 CIS failing better than most teams...
"An error does not become a mistake until you refuse to correct it" ~JFK
  #63   Spotlight this post!
Unread 12-11-2014, 10:39
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
I was going to start with "where in STEM is trail and error?", then I realized...
STEM: Science, Trial, Error, Math.
Thought that was funny.
  #64   Spotlight this post!
Unread 12-11-2014, 11:07
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
A lot of great inventions are a result of an accidents or observation of an unplanned events. Vulcanized rubber, post it notes, Penicillin are good examples of this. The intelligent, documented observation of the event is what distinguishes from the "hey watch this" type of randomness.
Since the people with the money don't like the term trial & error, you can always call it experimentation or research. Both calculation & experimentation are useful tools to solve a problem. Engineers are really just applied problem solvers.
If you don't know what you should hook up then you should read a data sheet
  #65   Spotlight this post!
Unread 12-11-2014, 11:56
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Often the hardest part of this is fully understanding what parameters are actually affecting the situation, as well as to what degree they matter. This is where having a theoretical understanding of the mechanisms at play (i.e. a model) is very useful - it tells you where to look. And thus experimental variables were born...
At work recently a colleague of mine and I spent hours trying to work out the math for a particular problem. Couldn't figure it out to a satisfactory result. So, we just started testing and *poof* the answer revealed itself. However, had we not at least TRIED to do the math we wouldn't have known what parameters to vary in our experiments.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
