Go to Post I don't really care that the best on Curie may or may not be better than Newton, since we're going to spend the rest of the offseason discussing it no matter how the decision fell. - Jessica Boucher [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 04-08-2014, 19:54
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Rookie Year: 2011
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Gear Face Width
I'm curious about the face width of gears in FRC. Especially as it relates to aluminum vs steel and diametral pitch.
Basically every 20dp gear in FRC is .5 inch face width. With that thickness there is certainly no reason to use steel gears.
However how much load can an aluminum gear stand at .5 inch face width? And how thin could they be made before becoming too weak for a relatively high load FRC application? Also, does there become a point where a steel gear with a very thin face width (so that the weight is comparable to a thicker aluminum gear) becomes as strong as a .5 inch thick aluminum one. At that point it would make sense to use steel as you're not sacrificing weight or strength but you're saving space.
On the same note, what if one were to use 32dp gears (or other comparable small tooth size) with a thicker face width instead? You would save a lot more weight and space than you would by making 20dp gears thinner.
Unread 04-08-2014, 20:09
Andrew Lawrence
Posts: n/a
Re: Gear Face Width
All VP/WCP gears are .5 total width, but a .375 face width. This is because of the two .0625 thick nubs on either end of the gear.
Unread 04-08-2014, 20:20
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
Re: Gear Face Width
Most FRC 20 DP gears have .375" face width, not .500", which is the thickness of the actual gear teeth. Vex sells almost all of their gears with little spacers on them that ride on the inner race of the bearing so that the gear's overall thickness is .500".
The gears we use see a huge range of torque. For some applications with the width they give us, aluminum is not enough. Drivetrains can see some very serious loads, upward of 120 ft-lbs at the wheel.
That being said, the first stage of reduction could possible be much smaller 32 DP gears.
If you're interested in getting more strength out of a gear, you can look at gears with a higher pressure angle. Most gears we use are 14.5 degree pressure angle, but 20 degree pressure angle gears are really common too. The higher pressure angle is a noisier and less efficient gear, but for FRC, the difference is not noticeable.
32 DP gears can't handle as much torque as 20 DP gears, but they work very well for the first stage of a gear reduction. I believe some teams have run 32 DP gears in the first stage of their drive gearbox, but I'm not positive on this.
If your main goal is to save weight, getting all non standard gears is a expensive and complicated way to do it. You'd likely get the gears in steel and have to do lots of machining to lighten them, and you'd additionally have to worry about putting the right keyway in them.
There are likely cheaper and far easier solutions to reducing weight. An entire 2 speed shifting gearbox, complete with side plates, mounting hardware, shifting parts, bearings, and shafts weighs under 2 lbs, and can be made lighter with more aggressive pocketing on gears.
Unread 04-08-2014, 20:39
Rookie Year: 2011
Re: Gear Face Width
Totally forgot about the hubs on the side. Not sure how that slipped my mind actually...
I'm thinking more along the lines of a team making it's own gears. I'm not asking if this is a good idea or not.
I just want to know if the gear sizes out there (20dp, aluminum, .375 face width) are the most efficient combination of DP, material, and face width or if there is noticeable room for improvement.
Unread 05-08-2014, 12:21
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Gear Face Width
When I've designed gears for machines, I've followed the criteria from 'Design of Machine Elements' by Spotts; there are two criteria that need to be worked out before you decide on material, diameters and facewidth.
First you need to work out the bending capacity of the teeth. without copying the whole text and the equations, I'll say that the bending is rarely the controlling failure.
Second, you work out the 'tooth capacity in contact stress' This involves not only geometry but also the moduli of elasticity of the sets of gears in the train. If you've ever taken apart commercial gear trains, you'll often see that the output gears may be steel but the earlier gears in the train may be brass or even plastic. The equations show you that different moduli make for better wear /stress capacity.
But you can get more stress capacity by increasing the face-width, so sometimes this is a substitute for using varied materials.
So the point is, if you want to 'design' gears, I recommend actually running through the equations and see where you are. A 'standard' face width may be fine, but just assuming probably isn't. if you need these equations, I can get them for you.
Unread 05-08-2014, 12:39
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Gear Face Width
This is only true for gears above 24 teeth. Pinions and gears under 24T from Vex are .475 face width, with just a .0125" nub on either side to get the total width to .500".
As for the OP's question about gear strength, if no one gets to it I'll answer that in a day or two, but someone smarter will probably beat me to it. A good first order approximation is to use Lewis numbers and model gears as cantilevered beams.
With regard to making gears, unless you want a different diametrical pitch (e.g. coarser teeth for an arm gear) you're probably better off just doubling the number of Vex gears on the shaft to double the effective face width. Very hard to speak in generalities here; it depends on the mechanism.
Unread 06-08-2014, 06:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Gear Face Width
I looked into using just 32 pitch, 20* pressure angle gears for the initial reduction stage once.
The problem is that your design actually won't get any smaller or lighter. This is because the CIM shaft is 8mm. A 20p or 32p gear that has an 8mm bore will have a diameter of around 0.6" regardless of its pitch. Then the mating gear will need to have a pitch diameter of between 2-4", regardless of pitch again, because the speed ratio is determined by the pitch diameters, not pitch.
If you want to experience this for yourself, just make a CAD model of a basic, single-stage gearbox and see what happens.
If you wanted to have a lighter primary reduction, making the 20p gears thinner would work much better. Or you could turn down the CIM shaft, but I don't know if that's legal. I know you can change mounting, but messing around with a cim shaft is iffy.
Cutting your own gears: depends. Involute gear cutters are expensive, and for a full FRC set of cutters (20 pitch, 14.5* PA, 12-100 teeth) it costs upwards of $400. I believe you can CNC them with a small ballnose endmill, but that takes up valuable CNC time. If you have access to a wire EDM machine that would be best. Those can cut gears quickly and effectively.
Waterjetting might work too. I know my local community college used to have a hobbing machine for gears.
I use this calculator for gear strength: http://www.botlanta.org/converters/dale-calc/gear.html
I have absolutely no idea about its accuracy, but I use it to compare the relative strengths of different pitch, pressure angle and face width gears. The most common Vex/Andymark gears in use in FRC today can withstand massive loads (such as my team's 600lb spring winch).
Unread 06-08-2014, 16:19
AKA: Pinecone
Re: Gear Face Width
In short, this isn't true.
In this case, two factors determine the minimum diameter (and by extension pitch diameter) of a gear. You are right in that the first factor is the shaft size - obviously the pitch diameter can't be smaller than 8mm. The second factor determining the minimum diameter of the gear is the tooth size. In theory, the smallest possible gear would have an outer diameter equal to the bore plus 2x the tooth height. Since a 32 DP gear tooth is much smaller than a 20T gear tooth (that's the point!), the pinion can be smaller as well.
In the real world, there needs to be some material between the bore and the root of the gear teeth for a gear to hold up, but not a lot. Let's say 1mm of material is needed between the bore and the teeth making the minimum root diameter 10mm, or .393 inches.
This root diameter is just shy of the root diameter of a 15 tooth pinion. A 15 tooth 32DP gear has an outer diameter of ~.531 inches and a pitch diameter of ~.469 inches. Compare these to the smallest practical 20 DP pinion*, 12 tooth, which has an outer diameter of .7 inches and a pitch diameter of .6 inches, and you can see that the 32DP pinion can be much smaller.
This allows for a reduction in a smaller space, even accounting for the greater number of teeth on the 32DP gear. Say you want a 4:1 reduction. That would be a 15:60 pair in the 32DP example and a 12:48 in the 20DP example. The 32DP gearset center distance would be ~1.172 inches, while the 20DP gearset center distance would be ~1.5 inches.
This is a great way to demonstrate that a 32DP initial reduction saves space. Just use the AndyMark 15T and 60T models (they're just pitch circles, by the way) and compare them to either AndyMark or VexPro models for 12T and 48T gears. On 2791's 2014 robot, we used the 32DP gearset to save space in several large reduction gearboxes. Our winch would not have been able to nicely package itself at the back of our shooter, with the winch rope popping out around the middle of the gearbox, if we did not use the 32DP gearset.
Also, some tips on lightening gears: If you can, I would pocket the gears at their current thickness before thinning them. You can take a lot of material out of a gear by turning the gear on a lathe and thinning the material between the bore and the root, or by drilling a hole circle into the gear. Done right, strength shouldn't be compromised at all (teeth still fail first) and you'll save a dramatic amount of weight.
* An 11 tooth pinion that doesn't use the 12T pitch circle is possible, but it gets a bit weaker than I'm comfortable with, especially when the 11T with 12T pitch circle gear is both COTS and much stronger.
Unread 06-08-2014, 17:42
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Re: Gear Face Width
Wow, that's a much more dramatic effect than what I have experienced. I stand corrected.
I think I said what I said, than 32p does not save space, because I'm used to designing side-by-side CIM gearboxes. This makes 32p impractical, because you need a minimum center-to-center distance of 2.56 inches anyway.
Unread 06-08-2014, 21:20
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
Team Role: Teacher
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Re: Gear Face Width
Sure, but only for that one usage case (2+ CIMS on a single gearbox).
If you're using non-CIM motors, or only 1 CIM, you can realize those gains.
See here for an example: http://media.team254.com/2012/08/gearbox.jpg
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 07-08-2014, 14:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Gear Face Width
For the more adventurous, you can turn down the shaft diameter, and add an aftermarket gear (like the ones for the RS-series motors). You could also cut gear teeth in it directly.1
1 For the most adventurous, if you really want to go crazy to prove the point that we aren't limited by the shaft diameter, and aren't averse to some creative fixturing and metallurgy, you might even be able to machine it, then harden it in place, and finish-grind the diameter (to maintain concentricity) and the teeth (to clean up the profile). That would permit a very small, strong shaft. This isn't remotely easy or cheap, and it's virtually inconceivable that any FRC team has ever tried it. You'd need a lot of very direct heat and a lot of heatsinking ability to avoid cooking the varnish in the motor or demagnetizing the magnets, while still changing the phase of the steel at the tip of the shaft. Then you'd need to quench it fast. And finish grinding of gear teeth essentially requires a custom fixture, which you'd have to build. (Note that if the next set of FRC rules have a definition of modification that allows disassembly of motors, this becomes a fair bit easier.)
Unread 07-08-2014, 20:52
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Re: Gear Face Width
Actually, you can open up the CIM and remove the shaft for machining. I distinctly remember one team did this. I think is was to allow CIM mounting to a versaplanetary.
Unread 08-08-2014, 03:58
Rookie Year: 1999
Re: Gear Face Width
There are two issues: firstly, the definition of modification and secondly, the utility of removing the rotating portion of the CIM.
Modification isn't straightforwardly defined, particularly because it's difficult to account for the cases where something is disassembled, and then reassembled in a functionally-identical way. When the assembly was apart, it was clearly modified, but it is arguable whether reassembly restores it to an unmodified state, leaves it in a functionally-identical modified state that negates the illegal modification, or leaves it in a functionally-identical illegally-modified state.
As for removing the CIM shaft, although it's straightforward to open the motor up and detach the rotating parts from the fixed ones, I don't recall it being practical to remove the CIM shaft from the armature. As a result, overheating the varnish is still a concern (but overheating the magnets would not be). But you're correct that this would nevertheless simplify the process significantly.
