I redid the Drivetrain code to normalize the motor values. How is the code? (Just ctrl-A ctrl-V'd it)
Code:
// RobotBuilder Version: 1.0
// This file was generated by RobotBuilder. It contains sections of
// code that are automatically generated and assigned by robotbuilder.
// These sections will be updated in the future when you export to
// Java from RobotBuilder. Do not put any code or make any change in
// the blocks indicating autogenerated code or it will be lost on an
// update. Deleting the comments indicating the section will prevent
// it from being updated in the future.
package org.usfirst.frc1127.DevBot2014_2015.subsystems;
import org.usfirst.frc1127.DevBot2014_2015.RobotMap;
import org.usfirst.frc1127.DevBot2014_2015.commands.*;
import edu.wpi.first.wpilibj.*;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Drivetrain extends Subsystem
//constants
final double DISTANCE_X = 1.0;
final double DISTANCE_Y = 1.0;
//only needed for field-centric
final double PI = 3.1415926;
//wheel velocity values | positive x values are right | positive y values are forwards
private double[] motorValues = {0.0, 0.0, 0.0, 0.0};
//rotation is cw
private double rotationX;
private double rotationY;
//field-centric stuff
private double curr_gyro_angle_degrees = 0.0;
private double curr_gyro_angle_radians = 0.0;
private double cos;
private double sin;
private double temp;
//for the for loop
private int i;
double maxValue = 1.0;
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
CANJaguar cANJaguar1 = RobotMap.drivetrainCANJaguar1;
CANJaguar cANJaguar2 = RobotMap.drivetrainCANJaguar2;
RobotDrive robotDrive2X = RobotMap.drivetrainRobotDrive2X;
CANJaguar cANJaguar3 = RobotMap.drivetrainCANJaguar3;
CANJaguar cANJaguar4 = RobotMap.drivetrainCANJaguar4;
RobotDrive robotDrive2Y = RobotMap.drivetrainRobotDrive2Y;
Gyro gyro1 = RobotMap.drivetrainGyro1;
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
// Put methods for controlling this subsystem
// here. Call these from Commands.
public void initDefaultCommand()
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
setDefaultCommand(new DriveWithJoysticks());
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
public void TakeJoystickInputsAndDrive(Joystick left, Joystick right)
calculatedDrive(left.getY(), left.getX(), right.getX());
void calculatedDrive(double y, double x, double rotation)
//Field-centric adjustments. Comment out for robot-centric.
curr_gyro_angle_degrees = gyro1.getAngle();
curr_gyro_angle_radians = curr_gyro_angle_degrees * (PI / 180);
cos = Math.cos(curr_gyro_angle_radians);
sin = Math.sin(curr_gyro_angle_radians);
temp = y * cos - x * sin;
x = y * sin + x * cos;
y = temp;
//This code is needed for both robot-centric and field-centric
rotationX = rotation * DISTANCE_X;
rotationY = rotation * DISTANCE_Y;
motorValues[0] = y - rotationY;
motorValues[1] = y + rotationY;
motorValues[2] = x - rotationX;
motorValues[3] = x + rotationX;
maxValue = 1.0;
for(i = 0; i < 4; i++)
if(motorValues[i] > maxValue)
maxValue = motorValues[i];
if(maxValue > 1.0)
motorValues[i] = motorValues[i] / maxValue;
drive(motorValues[0], motorValues[1], motorValues[2], motorValues[3]);
void drive(double y1, double y2, double x1, double x2)
//left, right
robotDrive2Y.drive(y1, y2);
//front, back
robotDrive2X.drive(x1, x2);
public void stop()
robotDrive2Y.drive(0, 0);
robotDrive2X.drive(0, 0);
