Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 19-08-2014, 00:02
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: 2015 Beta Testing - The Components are Here.
Originally Posted by timytamy View Post
On the diagram under the custom electronics port, it shows that the DIO has been pulled up to 3v3, implying that it uses 3v3 logic levels. Could you clarify, what logic levels does the RoboRIO use on both the main IO and MXP port? I believe I saw a voltage selection jumper on some alpha pics, implying that voltage is selectable, does this work and does it affect both the main-IO and MXP or just one?
Here's the jumper. The DIO power is 5v by default.
Also your MXP pin-out is out of date. It appears that the roboRIO will get a different configuration to the myRIO (https://decibel.ni.com/content/docs/DOC-30419)
Thanks, I updated that diagram.
Unread 19-08-2014, 00:18
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
The jumper only affects the DIO power pins on the built-in DIO connectors. The MXP has both power supply rails included, so the board may use either one as needed. The I/O itself in both MXP and built-in DIO is not affected by the jumper. All DIO is 3.3 V drive and 5 V tolerant.
Unread 20-08-2014, 23:33
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Does this means that we can use 5v devices (provided they read a 3v3 signal as high) without any risk of damaging the RoboRIO? I'm just thinking about various sensors and custom circuits that were designed for 5v that may perform differently at 3v3. They can probably be re-designed but it would be nice if that wasn't necessary.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 21-08-2014, 17:33
Rookie Year: 1997
yes
Unread 18-08-2014, 19:58
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Originally Posted by Tom Line View Post
Absolutely!!!!! That's why we put them up, and that's the whole point of Beta.
Thanks Tom. I appreciate it. The pictures are good and clear.
Unread 21-08-2014, 19:37
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
I'm looking at the power board/pneumatic bumper, and it seems to me that the pneumatics bumper has a relay/other driver built in to power the compressor. It also is powered from a fuse, which looks like
https://www.eficonnection.com/eficon.../mini_fuse.jpg , which is smaller than the spike fuse, meaning our normal 20 amp resetting breakers won't work here.
How do we replace the 20 amp fuse shown in (http://www.team358.org/files/program...mages/PDP2.jpg) that picture with an auto resetting one?
Unread 21-08-2014, 20:00
RufflesRidge RufflesRidge is online now
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
You don't...
Unread 21-08-2014, 20:51
Jared's Avatar
Rookie Year: 2012
Originally Posted by RufflesRidge View Post
You don't...
If you use a 20 amp not resetting fuse, as shown in the picture and the robot's battery is a little low, it trips when the compressor starts, leaving your robot without a compressor in the middle of the match. It's happened to me before.
The people who make this know this (as the manual has an exception for this), so either I'm not understanding how this works, or their will be issues with the fuse getting blown during matches. I'm betting that I don't understand how this works, and was wondering if somebody who actually has the part knows how it would work.
Unread 21-08-2014, 21:17
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Given both the pneumatic module and the power distribution board are connected to the RoboRIO via CAN, there is a possibility that these devices are monitoring the current to prevent fuse blowouts that the comparatively simplistic implementation "on off with a relay" on the old system couldn't compensate for.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 22-08-2014, 00:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
To my knowledge - we didn't see any blow fuses during Alpha testing.
The CTRE guys will need to answer this one. I'll fire them an email.
Unread 22-08-2014, 08:02
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
You can get self-resetting circuit breakers in this form factor fairly easily.
Amazon
Grainger
Unread 22-08-2014, 12:27
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Originally Posted by Nate Laverdure View Post
Self-resetting breakers usually do not trip as precisely as fuses. If the downstream circuits really cannot handle >20A, even for a second, you ought to use a fuse.
Unread 22-08-2014, 13:21
FRC #2363
Team Role: Coach
Rookie Year: 1999
Fine, but aren't we're talking about an application (powering the compressor) where self resetting circuit breakers have been used successfully for some time?
Unread 22-08-2014, 14:53
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
With different hardware, yes. From what I've been told in the past, Vex (the makers of the spike relay) did specific testing with a circuit breaker to validate it as safe before FIRST allowed it to be used for compressors in the rules. That's the only reason teams were allowed to replace the provided fuse with a breaker for use with compressors.
For FRC usage, breakers, in general, are present to protect the wiring, not the components attached to that wiring. For this 20A fuse, it could protect the PCM from over-current if (for example) something gets shorted out... but my guess would be that the fuse is there to prevent the PDP from burning out by drawing too much current from those outputs. It's probably there to protect against a short much more than to protect downstream circuitry.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
  #15   Spotlight this post!
Unread 22-08-2014, 19:12
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
I'd be very surprised if replacing the PDB fuse with a breaker will be legal for competition.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
