pic: New swerve CAD from 2471
Re: pic: New swerve CAD from 2471
Seems like a pretty daring design, having the modules on the outside. Have you made sure that the modules won't be affected by a hard hit?
It is a somewhat daring design. Although there will be structural bumpers outside of the modules, that will distribute impact forces evenly across two modules and the surrounding welded frame.
I'd be worried about the strength of using pocketed 1/8" wall tubing to support the weight of the robot and the forces from the wheels. Most swerves I've seen with a similar coaxial setup use 1/4" plate.
I like the originality of you module packaging, why did you choose to do it this way? Why have the modules on the outside? It would seem like your frame would be stronger and you'd have more electronic placement space with the framerails on the outside. -Adrian |
The packaging was chosen to minimize the distance that the modules will have to carry the weight of the robot, before distributing that force to the frame. As well as to minimize weight and maximize space in the center of the robot. If the frame were on the outside, there would have to be an extra inch of space left empty in the belly pan around the modules in each direction. This space would be necessary to remove the swerves, because the frame is C channel that raps around the top and bottom of the module. Thanks for your questions and feedback! ![]() |
Very cool! Will this make it on a BunnyBot this year?
Also, what is your reduction off of the CIMs? It looks like it will be on the fast side but maybe that's what you intended. Last edited by Dale : 18-08-2014 at 20:31. |
The reduction is quite fast, although it's a bit slower than what we ran last year. The final reduction is 3.6:1, or approximately 2.4 inches per revolution of the CIM shaft. |
Hmmm... looks somewhat similar to one I've seen before...
just make sure the C brace the swerve's attach to are not shaved completly flat, or you might lose strength in the frame. also are you not worried that the belt might slip off the larger gear because its not flanged? also most years bumpers must be supported every 8 inches do they mount on the swerves, or is there an additional bracket that is hidden? Last edited by kk052 : 18-08-2014 at 19:28. Reason: added something about bumpers |
Well you certainly won't be winning any pushing battles going that fast but on the up side, if it works as well as last year, maybe you won't need to!
#10
I still think its geared a bit high. |
#11
Even so, I would be worried about collisions at that speed on the modules. A hard hit on a corner could render you immobile, as well as costing a few hundred dollars. Even if nothing breaks mechanically, encoders are pretty fragile. With frame perimeter rules, are you really gaining extra room this way? |
#12
It's also going to impact acceleration. I suspect being geared that high the robot will seldom actually get to top speed during a match before having to change direction. Usually robots geared that fast will have six CIM drive trains just for that reason.
#13
I think you'll find that a robot geared for 14 fps on 4 cims will have plenty of power to accelerate quickly. Our comp bot did fine this year, and it was geared for about 18 fps. Our bunny bot was geared even faster that that, and it won. so obviously, it will depend on the game, but in my opinion, 14 fps isn't "too fast".
#14
I'm not really sure what you mean by "With frame perimeter rules, are you really gaining extra room this way?" |
#15
