#16
Re: pic: New swerve CAD from 2471
I forgot to post the estimated weight. According to inventor, these modules will be over a pound lighter that last year's model: Weighing in at 6 lbs each.
Including all that is pictured except the bumper, the drive base should weigh about 30.5 lbs. |
#19
Absolute encoder. TT electronics 6127 series. .25 to 4.75 volt output. more like 11$ a piece. Used on our swerve for 3 years now. Like them.
#20
Yeah, we've used those encoders sense champs this year. |
#21
Thanks, what's the rotate over point look like? Just a transition from high voltage to low? Can I simply map 0-360 to .25-4.75 and call it a day?
#22
You can also get the flattened shaft version, so that set screws won't slip. |
#23
Thank you, just saved me a a fair bit of money in encoders.
#24
Can you post the link to the encoders please?
#25
my guess is they are talking about this part:
http://octopart.com/6127v1a360l.5fs-...ogies-19910150 There are a number of different options it can be ordered in, see data sheet Note these are rated at 500 RPM in the datasheet. So they likely more than sufficient for monitoring the position of a part - like the wheel's heading in this case. Without proper gearing they are likely not a good choice for use on things like a shooter wheel. If you're looking to monitor wheel rate of travel over ground, these aren't appropriate unless you've got wheels bigger than 6" or have geared the encoder down (assuming you're targeting a top speed or around 14fps). |
#26
Plus it's an analog output so in a high RPM application you'd be monitoring a saw tooth signal on the analog port.
#27
Looks very cool! And yes, I assume they are using this part http://componentsearch.com/search/se...127V1A360L.5FS
