Go to Post Everyone please breathe before you post. - Jessica Boucher [more]
Unread 28-08-2014, 00:19
Drew4564 Drew4564 is offline
It's Tape Measure Time!
FRC #4564 (Orange Chaos)
Team Role: Driver
Rookie Year: 2013
Drew4564 is an unknown quantity at this point
pic: Modified AM Shifter Gearboxes
Unread 28-08-2014, 00:20
Andrew Lawrence
Posts: n/a
Re: pic: Modified AM Shifter Gearboxes
I apologize if I'm missing the obvious, but aside from the gold coloring what modifications have been made to this transmission, and why did you make them?
Unread 28-08-2014, 00:40
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Appears to be a 1st generation shifter, with its internal double sprocket, with the addition of an external extended output shaft, like a super shifter.
Unread 28-08-2014, 00:43
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Rookie Year: 2011
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
This is an AM Shifter. It is normally gold.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 28-08-2014, 00:46
Andrew Lawrence
Posts: n/a
Originally Posted by jspatz1 View Post
Appears to be a 1st generation shifter, with internal double sprocket, with an additional external extended output shaft, like a super shifter.
I didn't see the extended shaft on the first time around - thank you for pointing that out.
Unread 28-08-2014, 00:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
This looks surprisingly lightweight. Perhaps replacing the cylinder with a smaller one would be good though.
Unread 28-08-2014, 01:00
Team Role: Driver
Rookie Year: 2013
We made them simply for the fact that we had two given to us by a retired team, and it was a much cheaper process than buying new ones. I agree that a smaller piston would be desirable, but I'm not sure what would work as a replacement.
Unread 28-08-2014, 01:06
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
If your looking for something more compact I'd recommend either:
Bimba Flat - 3/4 Bore (due to #10-32 male thread), could do 9/16" bore as well
FO-040.5-MT
or
VEXpro Pancake
You will probably have to modify spacer length as an FYI when switching to a pancake cylinder.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 28-08-2014, 16:25
Team Role: Driver
Rookie Year: 2013
FO-040.5-MT
or
VEXpro Pancake
My team will definitely look into these, thanks for your help! The current cylinder is much larger than it needs to be, and would take up a lot of space at the bottom of the drivetrain.
Unread 28-08-2014, 09:46
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
These older gen-1 shifters are almost entirely steel (sideplates, gears, sprocket, shafts, dog, bearings, bolts) so they are actually quite heavy, but they are durable.
Unread 28-08-2014, 15:40
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
I like it as an engineering exercise. Were you planning on using these for next season?
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 28-08-2014, 16:23
Team Role: Driver
Rookie Year: 2013
Yes, we are planning on using them for next season, and are currently in the process of building an off-season drive with them! It was a great way to learn Solidworks for my team, as we had to not only modify the gearboxes but put them on a WCD.
Unread 28-08-2014, 17:51
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
To obey fab schedule rules, you will need to disassemble them to their original COTS state, and replace and redo any modified parts.
Unread 28-08-2014, 20:10
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
I agree, this is the legal way of doing this.
A separate discussion altogether is, how many teams actually follow that vs teams that don't.
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
  #15   Spotlight this post!
Unread 28-08-2014, 20:38
HP42S HP42S is offline
Rookie Year: 2020
HP42S is an unknown quantity at this point
Funny you should mention this. It was about 1 year ago when I was looking a little closer at possible FRC participation and as a total FRC noob couldn't figure out why everyone on CD was showing off their new drives before kickoff. So I asked a question on CD and was politely told how off-season work could be done. Got a much better understanding now
Still trying to figure out if it's really worth stepping up to FRC..... seems to me like the odds are stacked against 1st, 2nd and maybe even 3rd year teams.
