Re: Recommendations for chain drive lubrication?
What cleaning solution do you use in this product? |
I think you could run water and degreaser through it, then regrease the chain with the same machine.
That product is for mountain bike chains. Chains that live in a nasty environment, mud, water, & sand. It cleans the side plates & rollers. Typically a surfactant like simple green & water. You move the chain through it, no soaking. Being cheap, I just use a rag soaked in cleaner to the same effect. I have yet to see a FRC robot chain that dirty. Maybe for next years water & mud game?
No, I was just wondering if using a chain cleaner to do it would get the lube back in better.
Head to local bicycle shop and pick their brains. I mountain bike for years and used both the park an the Pedro's machines dry. I used to use dry lubes on my chain to avoid dust and such from sticking. Personally if the chain was that bad I just replaced it, usually once a year sometimes twice.
I the chain is really that bad replace it. #25 chain is relatively inexpensive.
I've been using the stuff in the link below for years on bicycle and motorcycle chains. It's very thin going on and flushes a lot of debris out of the links, then dries almost to a wax. Once dry, it stays put and is nearly dry to the touch. A can should last several seasons.
http://www.amsoil.com/shop/by-produc...?code=AMHSC-EA Use it in a ventilated space, because it gives me an instant organic solvent headache until it is dry. YMMV. |
