cRio requires imaging before every deployment
We are having an issue with one of our cRio's. Whenever we want to deploy modified code to it, the process fails as LabView goes into a loop while waiting for the cRio to respond.
With a couple off season tournaments left, we want to be able to modify our code when needed. Currently the only solution we have found is to run the cRio Imaging tool and format it first. When we do this, we can deploy the newly modified code. The problem is, this is quite time consuming and doesn't always work well between matches.
This "failure mode" used to only show up every now and then, but lately, it happens every time.
Has anyone else had this issue, and if so, did you find a solution and what was it?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
