Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
Unread 09-09-2014, 19:42
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
[Ri3d] Ri1W Unveil Video
We decided to have a slightly delayed release of our final video. But here is the full unveil video!
http://youtu.be/t-eT2WtyBzk
Big thanks to everyone who came out an helped, all the FTC teams and supporters out there, and our sponsors.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 10-09-2014, 18:28
Aidan H.'s Avatar
Aidan H. Aidan H. is offline
Unregistered User
FRC #3260 (SHARP)
Rookie Year: 2013
Aidan H. will become famous soon enough
Re: [Ri3d] Ri1W Unveil Video
I loved the reveal video and thought it was a good balance of "entertaining" and "informative" on how you went about building the Ri1W robot.
I did have a few questions about the materials you used:
Where did you buy the 80/20 (I think it is the smaller size)?
Where did you get the polycord (urethane belting) that you ended up using on your pickup?
Did you find it hard to maneuver on the field and interact with field elements (goals, balls) without having an omni-directional drive?
2016 - Greater Pittsburgh Regional Engineering Inspiration Award
2014 - Greater Pittsburgh Regional Winner
2013 - Pittsburgh Regional Finalists
2013 - Buckeye Regional Finalists
Unread 10-09-2014, 19:07
Git 'em!
Rookie Year: 2000
One of our team members (JR) works for an 80/20 distributor, he gives discounts to Florida FTC teams he works for Florida Motion and Control.
The polycord was purchased from McMaster its called Urethane Solid Core Round Belting, there are many options depending on how your going to use it.
The goals are large and stable enough that lining up wasn't too terrible, although getting the end effector lined up to score was tricky, I would put some mechanical alignment devices on the bot to aid the drivers with that if we were taking the bot to a tournament. Acquiring balls was relatively easy because there are so many of them its not like your having to aim to get one specific game piece. Then again we weren't in a match with 3 other robots, one thing was its easy to ride up on the smaller balls so teams might consider skirts or something to keep balls from under their chassis.
Robot in 3 Days
