Go to Post Just remember to never take the "Us vs Them" mentality and you should come out all right. - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 14-09-2014, 01:14
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Re: Experience With 6 Cim Drive train
Originally Posted by Joe G. View Post
  • Coded our drivetrain to automatically drop to 4 CIMs when running our shooter winch or intake motors, with the driver given a trigger to override this in high-pressure situations
Does this mean you were running (at least one pair of motors) in coast mode?
I suppose there probably isn't a huge difference between 4 and 6 brakes, so it doesn't matter I guess
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 14-09-2014, 13:12
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Yes, two motors were on coast.
I'm sure you already considered them, but in the event you didn't know about them, did you look at the 11 (or 13 tooth if you were running 14 tooth CIM pinion gears) tooth gears to drop in to replace the 12 tooth pinion gears?
We were running 11 tooth pinions at each of our events.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 14-09-2014, 20:32
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
There are some interesting ideas here for dealing with main breaker trips.
I think the best solution is to gear more conservatively and enjoy the extra acceleration. For short distances, slower is faster. The last two years we have run a 6 CIM single speed drive geared for around 11-12 fps, and have never tripped the main breaker. We have used a spreadsheet to help optimize our gear ratio, and this speed seems to be a sweet spot for single speed drives. It provides great acceleration, and the current demands are low enough not to trip the main breaker. Most of the teams I have talked to about breaker problems were geared higher than 12 fps.
Unread 14-09-2014, 10:32
Juan Martinez's Avatar
Juan Martinez Juan Martinez is offline
AKA: Fix This
FRC #0051 (Wings Of Fire)
Team Role: Driver
Rookie Year: 2012
Juan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to allJuan Martinez is a name known to all
Originally Posted by inkling16 View Post
Is this the gearbox you used? If so, how did you achieve a 1.5x spread?
My bad I meant 18 and 8, I was thinking about 2 different robots
Unread 13-09-2014, 18:59
Deke's Avatar
Deke Deke is offline
no team (No Team)
Rookie Year: 2013
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
I certainly disagree with that. I find shifting to a low gear (<7fps) to be a very valuable asset, in more situations than just precise movement.
While our 5fps was definitely too slow to play the whole match in, there were numerous times (especially in the defense heavy game) that you just needed to knuckle down and bulldoze your way through a pileup. Our robot used 3" Colson wheels, had the bumpers at the lowest point, and had a center of gravity roughly 5" from the floor. We could push nearly everyone, and many tank robots saw themselves skidding sideways by us. We did not have a traction problem at that torque either, and our used wheels had little measurable diameter difference to new ones, to the naked eye.
So then the other positive is pushing correct?
There are a lot of factors involved but just to be simple, the system doesn't need to be designed to 40 amps per motor to push someone. That's why I said the low gears are too low. They are over designed for the 150 second matches to push people around, and too slow to be useful in normal driving.
I would say you can comfortably design them around 60-65 amps per motor to push, based on what we saw our drivetrain do this past year. I would like to try 70-75 amps per motor this year and see what the breakers can take, should be fun.
Unread 13-09-2014, 19:20
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is online now
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Readers of this thread might be interested in this one from 2013.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 13-09-2014, 22:51
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #1736 (Robot Casserole)
Rookie Year: 2011
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Great! 6 cims driving 3 cim ballshifters geared 12ft/sec and 5.5 ft/sec. Kit drivetrain upgraded to 8wd long. Traction limited in high, estimate of around 200 amps spinning in high using drivetrain calculator on WCP website. Played tough D in high a lot at central il regional, no trips. No trips at Wisconsin either. Standard wiring sizes, noticed some heating in wiring and battery, no failures, no major concerns. 6 cim acceleration made for some great defensive capability.
We will seriously consider 6 cim single speed next year at 12 ft/sec unless game dictates otherwise.
Heres a short video showing some highlights from cental IL for those interested:
http://m.youtube.com/watch?v=IQqoqUNYt_c
Edit: To clarify, we almost never used low gear all year.
Unread 13-09-2014, 23:56
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
FRC #0973 (Greybots)
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
CV Robotics has used single stage 6-CIM gearboxes for the last two seasons. Our experience has been great with this drive type.
While our boxes are geared for 17.5 FPS theoretical, our actual speed is ~16 FPS. We really like the increased acceleration we get, even at a higher speed of 17.5.
Electrically, we popped the thermal breaker three times this year.... twice it happened immediately after we had been in a prolonged pushing match (8-12 seconds) which is a bad idea in any case.
The other time was a fluke incident, one of the nuts on the PDB came loose and it induced a huge resistance into the system, nearly melting the plastic on the standard size power leads.
Other than that, our system remains relatively cool throughout operation with the exception of the breaker and Rear CIM plates. We have no dedicated cooling, and this year we did nothing to cool the robot between matches. However, next year we are planning on introducing some protocol to cool our main breaker and CIM's which get to 46 C/114 F occasionally.
We didn't run an on-board compressor last year, and all of our other motors were used intermittently. This gave us some extra time before the breaker thermally tripped because of reduced current demand.
Overall, we consider our 6-CIM drive to have been integral to our success the last two years. Our plan is to continue with 6-CIM unless it isn't useful for the game. Ie. If the increased acceleration/torque isn't useful next year
We recommend it
(2015-?): 973
(2012-2015): 955
Unread 15-09-2014, 11:46
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Team 716 used our first ever six cim drive and it was absolutely awesome. I couldn't ask for anything better, As the driver I didn't really see the need for the two speed so we only used a one speed, which ended up being about 15 fps. (we decided to use only the single because this game was based strictly on time so you did not want to get into a pushing match but instead wanted to zip around everyone.) It turned out though that we could still push 80% of the robots that we went against. in regards to your question, I would assume you would want to avoid an extended pushing match because it wouldn't be worth the time lost.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 15-09-2014, 13:44
Chris is me's Avatar
AKA: Pinecone
6 CIM drive, single speed geared for 13 FPS actual (measured) speed. 6.11:1 on 4" Colsons, if you want to do the math yourself. Treaded them for regional 2, plain for regional 1.
We had no problems tripping our breaker all season, however we did design our entire robot around preserving current. We modeled how much air our pistons might use and went with 4 plastic air tanks in order to leave the compressor offboard. Most teams only leave the compressor offboard if they have weight problems, but I think current draw is a much more important reason to consider leaving it off. To keep current draw low we used relatively few motors across the rest of the robot. Other than the drive we had just one BAG motor for the intake, one mini-CIM to drive the arm, which we partially balanced, and one mini-CIM to retract the winch, which we geared down significantly to reduce the load on the motor.
We never did take off two motors to compare the performance of a 4 vs 6 CIM drive, so all of these opinions are pretty worthless... but purely subjectively, the 6 CIM drive seemed to accelerate faster and felt more responsive than a 4 CIM drive. Interestingly, with regard to the 40 amp breaker, we found that when the 6 CIMs stalled against a heavy load, the 40 amp breakers tripped less quickly than with a 4 CIM drive. Obviously part of this is because the load is distributed across more motors, but the drive was fully stalled so each motor should have been at its max current draw. What we later realized is that with more motors, the voltage drop was greater, resulting in the motors drawing less current at stall (and also having a lower stall torque at the lower voltage). Thus, the 40 amp breakers are less of a constraint in our particular configuration with 6 CIMs than they are with 4.
Unread 15-09-2014, 13:59
Oblarg Oblarg is online now
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
This is consistent with my own observations. We had the same gearing/wheel size this year (HiGrip wheels instead of Colsons, though), and had no problems with the breaker except when the compressor was running.
Interestingly, we found that the compressor (and, by extension, any other power-consuming device on the robot) caused a twofold problem: not only does it draw current, but it lowers the effective voltage of the battery which can result in stalling a drive that would otherwise be traction-limited. This is crucially important, since if you're going to last in an extended pushing match you absolutely must be traction-limited.
Re: having less problems with the 40A drive breakers, we experienced this, too. Unfortunately, we found that unless you're exceedingly careful with current draw, at aggressive gearing going from 4 to 6 CIM SS basically results in swapping problems with the 40A breakers for problems with the main breaker. We plan to do a two-speed drive next season.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
