Go to Post 1114 is the definition of what a FIRST team should be. For anyone to say otherwise is disgusting to me. - Andrew Schreiber [more]
Unread 12-09-2014, 16:08
5383robotsrule's Avatar
5383robotsrule 5383robotsrule is offline
FTC #5384 (code red robotics family of teams)
Team Role: Driver
5383robotsrule is an unknown quantity at this point
Exclamation ftc mecanum code
Hi I was wondering if anyone had any FTC mechanum teleop code.It would be greatly appreciated
there are no mistakes only lessons
nothing is impossible some things are harder than others :yikes
Unread 12-09-2014, 20:19
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Rookie Year: 2013
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: ftc mechanum code
Not exactly what you asked for, but for frc we just implemented Ether's math (click here for the documents) and went from there. Start with the "mecanum & omni with gyro for field-centric control", it should give you all the math to setup the motors initially. If you don't have a gyro you can just set it to zero or not include it at all. Hope this helps!
Unread 12-09-2014, 22:35
dawonn's Avatar
dawonn dawonn is offline
Mentor
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Don't skip the gyro, it's the difference between frustrating year and an awesome year.
You don't have to use field centric control with a gyro either, that can be a headache too.
Unread 13-09-2014, 17:03
Team Role: Driver
Re: ftc mecanum code
the problem with the gyro is we don't have a gyro to use . i am also not very good at coding so i don't understand how to do a lot of stuff with coding.
Unread 13-09-2014, 17:47
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
https://www.hitechnic.com/cgi-bin/co...on&key=NGY1044
This one should work for your purposes and wouldn't be hard to wire.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 13-09-2014, 19:22
Team Role: Driver
this will work but i would prefer a code that doesn't require the gyro because this is kind of expensive and also the mechanum wheels cost $60 per set of 4 and we want 2 sets so thats $175 with gyro so it is expensive.
Unread 13-09-2014, 19:58
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
You don't need the gyro for Mecanum. We used it just fine without it this year. It is true that it would give a better experience but it totally is extra something to do if you have the time (and money).
It is something we have planned on adding every year never gotten it done. Now our switch to RobotC might make it harder to get to it this year.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 14-09-2014, 11:49
Team Role: Driver
Do you have any teleop code from your mechanum code from previous years
Unread 14-09-2014, 12:15
AKA: Roger Moore
Rookie Year: 2013
Here are the screen shots of our code.
There are 3 pictures.
The way it works by adding and subtracting the values of the joysticks depending of the wheel. The middle attempts to normalize the value of the joysticks because if you don't it will end up driving really fast all the time.
**I have not included our code from last year directly because we had a really weird problem with our code that we couldn't figure out. When ever the joystick value got higher than aprox. 100 the motor outputs were reversed. I rewrote this code several times and could never get it to work.
ID:	17310  Click image for larger version
ID:	17311  Click image for larger version
Stronghold
Student 2013-2016
Unread 14-09-2014, 12:53
Team Role: Driver
Talking Re: ftc mecanum code
thanks so much for the screenshots these will come in handy for programming our robot. i really appreciate it. now my team will be able to do mechanum. we have been debating on whether or not to use mechanum it all depended on if we had code or not.i could talk to one of our coders to fix your code problem.
