Go to Post FIRST people are just wierd like that. We get drawn to places in the middle of the desert as long as we know there will be more people like us there. - sanddrag [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 15-09-2014, 15:47
Jduffy Jduffy is offline
FRC #2451
Jduffy is an unknown quantity at this point
Re: Best gyro for frc.
We tried to use an MPU6050 breakout and arduino last year, but combining everything fairly difficult, so we just bought a nav6 from kauai http://www.kauailabs.com/store/index...&product_id=50
They're $70, but designed to work with a cRio out of the box, and will probably work with an rRio with a serial cable. It worked over usb to my computer, and the new rio runs linux, so it should be fairly easy to set up.
We used it to make our swerve field-centric, and it only floats by a degree or two throughout the match, which is about as good as you'll get with a cheap chip gyro.
If you want to make your own, arduino and an MPU6050 is a good place to start, there are several good libraries and explanations to get you up and running fairly quickly.
Unread 15-09-2014, 18:22
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
If you want to use the arduino and the MPU6050 and assemble something yourself, I highly recommend you ensure that the interrupt pin from the MPU-6050 is connected to the Arduino. This will allow interrupt-driven operations which is the way to get good performance. If you go to the nav6 website (https://code.google.com/nav6) you'll see schematics that show how to hook it up. All the nav6 open source code is available there too - and it's Arduino-compatible w/an Arduino UNO.
Do keep in mind that the MPU-6050 is a 3.3V part, and isn't 5V tolerant, so you'll need to take care of that. The nav6 does that, and also allows powering directly off the 12V robot battery.
One of the nice things about using the nav6 firmware, even if you assemble it yourself, is it will work w/all the WPI classes (java, C++) as well as w/the LabView VIs (these are also on the nav6 website). A few people who have the RoboRio beta systems are testing out the nav6 on the RoboRio, and although I haven't got word yet how well it's working for them we expect it should work just fine.
If you have any questions, please contact me at scott@kauailabs.com.
Unread 15-09-2014, 16:45
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Originally Posted by Mk.32 View Post
Is there a place to get an pre-made IMU for this gyro? Quick googling doesn't seem to bring up anything state side.
At some point, I'm going to make a board for it for the roboRIO. Given my schedule, don't hold your breath for it... It will most likely be available through WCP.
Unread 22-12-2014, 18:00
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Has anyone thought about making an aftermarket board that plugs straight into the expansion port on the rRIO that includes a gyro built in as well as pwm expansion and dI/O and analog expansion?
Unread 22-12-2014, 18:08
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Gyros are very sensitive to electromagnetic fields, this may be a problem so close to the roboRio.
Even if it wasn't, the chip I tried in particular is a single-axis gyro and will require more precise mounting on the robot. Many teams like to mount cRios/roboRios vertically or in a way convenient for troubleshooting or maintanence. Maybe an embedded 3-axis gyro would solve that problem, like the rRio's 3-axis accelerometer.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 09-01-2015, 11:46
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Figured I'd clear up a couple of responses in this thread.
Incorrect. MEMS devices are manufactured using non-ferrous materials, thus making them immune to strong magnetic fields. A single axis gyro simplifies the mounting on the robot. You only have one axis to worry about! The ADXRS450/453 are "rate gyros" which mean that they are designed to only report back...rate... in one axis!
Originally Posted by Bryce2471 View Post
Sorry I'm a little late to the party on this thread. As far as this gyro goes (ADXRS453), it looks like there are two packaging options (ADXRS453BEYZ and ADXRS453BRGZ), I'm wondering which one you would recommend, and how you interface with it.
You probably want the ASXRS453BRGZ version since the sensor will be easier to solder onto a PCB and the measured axis is located through the center of the part. You would solder the sensor down to the PCB just like any other IC. I would recommend purchasing the breakout board, though!
The 450/453 differ from the gyros used on the AndyMark breakout board in that the Analog to Digital conversion is performed within the sensor. This makes them much less susceptible to EMI. In an ideal setting, you would want the accelerometer attached to a rigid portion of your robot, and the gyro would be located as close to the center as possible.
Although the 6-axis and 9-axis sensors are cool, they are not designed for precision navigation applications. Noise levels on those sensors are orders of magnitude greater than what's available on application-specific sensors. I would strongly suggest that teams invest some time looking into the 450/453 if they want to have a solid drive system.
Another caveat of systems such as the nav6 is that they are not calibrated. Each sensor is unique and will provide a slightly different response when used in different applications. In that case, an integrated IMU such as ADI's iSensor product line would be ideal.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 09-01-2015, 14:57
Software Mentor
AKA: Scott Libert
I absolutely agree that there are much higher noise levels on 6/9-axis sensors, and the dedicated yaw-rate gyro like the ADXRS453 is a very good sensor for the field-oriented drive application. The 6/9-axis sensors in the nav6 are consumer-grade (e.g., iPhone, Oculus Rift), rather than the industrial grade of the ADXRS453.
However - please be aware that the nav6 is definitely calibrated, as it features factory-calibration of accel/gyro biases, and also continually re-calibrates the gyro biases during periods of non-motion (accounting for gyro temperature changes). This behavior, implemented in the Invensense digital motion processor (DMP) silicon and the on-board microcontroller, is what enables the yaw error rate of approximately 1 degree/minute. The navX MXP features the 2nd-gen MPU-9250 w/even lower gyro noise levels - so we're seeing this technology continue to improve and mature as the MEMS noise levels decrease, and the implementation of the data fusion and calibration algorithms continue to improve. More info on the gyro/accel calibration is available at: https://code.google.com/p/navx-mxp/w...celCalibration
The nav6 technology does require about 16 seconds of calibration time before a match, during which the robot must be held still. The navX MXP lessens this period, but this may be a difference between the two approaches worth noting.
The nav6/navX MXP technology is cost-effective and viable for use in a field-oriented drive system. Several teams have been doing this successfully, and enjoying the ease of integration it provides. Sounds like a bake-off between a ADXRS453 and a navX MXP would be helpful to the CD community....
Unread 20-01-2015, 17:48
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Ok - so when wiring up this Gyro, what goes where?
Gyro Ground to Roborio SPI Ground
Gyro Mosi to Roborio SPI Mosi
Gyro Miso to Roborio SPI Miso
Gyro PDD to Roborio SPI 5V power (datasheet says 3.3 to 5)
Gyro CS to Roborio SPI CS0
Gyro Clk to Roborio SPI Clk
Do I have this correct?
Since my experience is with analog gyros, what type of data am I going to see over the SPI interface that I will have to use to calculate bias and integrate to angle with?
Unread 20-01-2015, 18:30
ArthurA's Avatar
ArthurA ArthurA is offline
I think that I'm registered???
FRC #4774 (The DropBears)
Rookie Year: 2014
ArthurA has a spectacular aura aboutArthurA has a spectacular aura about
Our team took up writing and providing decent drivers for the MPU6050 as one of our offseason projects last year (2014) and had good results. We have very little drift (ie a couple of degrees every couple of hours, though we have yet to record exact results). We have a nice, cheap, solution that has been tested on a BBB and a raspberry pi, and we have half ported working code for the roboRIO (also working on using the MXP breakout board with it):
Links:
For BBB and Raspberry PI: https://github.com/thedropbears/DropBoneImu
For roboRIO (WIP, but it works): https://github.com/thedropbears/lib-4774
Documentation:
http://thedropbears.org.au/wiki/index.php/DropBone_IMU
Edit: Add link to documentation
Unread 06-02-2015, 10:53
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
We are wiring one up also. This pinout looks correct but I am unsure of one connection. Does MOSI connect to MISO on the other side? We'll find out this weekend I reckon. Has anyone written a class just for the ADXRS453 on the roboRio they might share? Will ADXL345_SPI (with relevant mods) work?
TIA
Fast, cheap or working - pick any two!
Unread 06-02-2015, 14:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
No, MOSI connects to MOSI. It stands for Master Out Slave In. It's an output from the roboRIO and an input to the connected device.
Unread 06-02-2015, 15:07
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Thanks!
Unread 08-02-2015, 11:36
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
TIA
There is demo software already written in LabVIEW for the 450/453, but I haven't seen anything for C++ or Java. Might want to check the examples!
I should also have a nice RoboRIO solution for the 345 & 453 that teams might be interested in looking at!
Unread 25-12-2014, 17:15
Software Mentor
AKA: Scott Libert
Kauailabs will be announcing exactly what you describe on January 3.
  #15   Spotlight this post!
Unread 25-12-2014, 18:09
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
What gyro specifically?
Thanks
