Go to Post Yes, it really is Bill Miller posting on Chief Delphi (Imagine that!). - Bill Miller [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 14-09-2014, 14:28
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Best gyro for frc.
I have been looking into different gyros online for an offseason project and am not sure which one to go with. The applications will be at least as demanding as FRC if not a good bit more. This means we would like minimal drift and for it to remain accurate under high acceleration.
Anyways could any teams who use gyros in their robot tell me which gyro they used and if they recommend it. (Shoutout to 1717 and 16, you all probably have good gyros for your swerve, it would be greatly appreciated info)
Unread 14-09-2014, 19:15
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Best gyro for frc.
1538 had very good results with Analog Devices gyros.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 14-09-2014, 21:53
RyanCahoon's Avatar
RyanCahoon RyanCahoon is online now
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
I used a ADXRS453 for the NASA Sample Return Challenge this year and was impressed with the performance for the cost.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 15-09-2014, 10:06
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
I had a opportunity to test several different gyros (from two different manufacturers) on an FRC robot for a personal project and like the others, I would recommend the Analog Devices gyros. The one I am currently using is the ADXRS450 (similar to the ADXRS453 above - except without the internal temperature compensation) and it works well. If price isn't an issue, higher quality gyros are available with some excellent specs, however they typically run more than $1000.
Mike
Unread 15-09-2014, 12:00
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
We've been using that gyro as well, and it works incredibly well. Very low drift, very low acceleration -> yaw coupling.
Unread 15-09-2014, 12:21
AdamHeard's Avatar
Lead Mentor
2 years in on the same gyro for us, I wish we had used it with our swerve in 2012!
Unread 28-10-2014, 16:03
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Rookie Year: 2012
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
Hey Adam,
I noticed that the pin out on these gyros are different from the KOP sensor board. How would you interface these with the control system we have with FIRST. I know you have to set up a SPI connection with SCLK, CS, MOSI, MISO, I just have no background with this.
EDIT: Found it. For anyone who wishes to know how to wire the ADXRS453. It is just like the accelerometer. You will take the SCLK, CS, MOSI, MISO to the DIO pins 1-4, doesn't matter really what order, and can power it from the 5V or Ground located below the DIO pin 1 location. Thanks all and hope this helps someone else out.
"There is no luck. It is only when preparation meets opportunity."
Unread 28-10-2014, 17:05
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
I assume you use the SPIDevice class in Java (for example)? If so, can someone with experience using the ADXRS453Z provide feedback on the correct bit order, clock polarity, clock rate, and frame modes?
Any sample code you code provide would be helpful, which could help avoid hours of troubleshooting.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 28-10-2014, 18:46
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
Team Role: Teacher
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
This guy if you don't want to use SPI:
EVAL-ADXRS642Z - about $75 from mouser, digikey, etc
http://www.analog.com/en/mems-sensor...s/product.html
Team 2590 Mentor [2009-2014]
Team 5895 Mentor [2016-Present]
Unread 28-10-2014, 18:47
AdamHeard's Avatar
Lead Mentor
Austin Schuh is really the best to answer those questions here.
Colin Wilson (254>973>254) made ours, and could also answer but he's less active on here.
Unread 28-10-2014, 19:48
Rookie Year: 1999
This is on my over-booked TODO list...
We had a co-processor reading it last year. We are putting together a board right now to interface one with the roboRIO. We'll be releasing our beta test code closer to the start of the season. I expect that we should be able to interface with it over SPI.
Unread 29-10-2014, 00:32
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Austin,
Do you expect any differences between integrating on your co-processor and integrating with the accumulator in the FPGA, in particular with integral error and drift? What was the SPI bus clock speed/integral dt on your co-processor? Do you happen to know the SPI frequency on the roboRIO? (I think I saw 4MHz in a myRIO document...)
Thanks,
Aren
Unread 29-10-2014, 01:28
seg9585's Avatar
AKA: Eric
How reliable is this gyro as an analog voltage output? The gyro on the ADXL345 (FIRST Choice, etc) simply didn't work for us, it had way too much drift to be useful. A typical 2-minute match resulted in >45 degrees of drift! Because of this, I've become skeptical of analog sensors requiring integration for attitude/position calculation (too much noise on the A2D probably led to these problems)
My FIRST legacy:
Unread 15-09-2014, 13:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Is there a place to get an pre-made IMU for this gyro? Quick googling doesn't seem to bring up anything state side.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #15   Spotlight this post!
Unread 15-09-2014, 15:23
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
The part # for the evaluation board is : EVAL-ADXRS453Z
Mouser and digikey sell these.
Never actually used this but I had it bookmarked to buy eventually.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
