Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 15-09-2014, 19:53
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Setting up Netbeans on a 10.5.8
I'm trying to setup a mac powerpc 10.5.8 with netbeans but whenever I reboot NetBeans after installing it gives me this error
Warning - could not install some mdules:
FRCSquawkSDK - The module named edu.wpi.first.wpilibj.templates/2 was needed but not found
FRCSquawkSDK - The module named org.sunspotworld.renamerefactoring/2 was needed but not found
FRCSquawkSDK - The module named org.sunspot.SPOTFRCwelcomemodule/2 was needed but not found
FRCSquawkSDK - The module named org.sunspotworld.sunspotfrcapplicationtemplate/2 was needed but not found
Netbeans 6.5, Java 5. (ios 10.5 cant run any higher than that, due to this I don't install the command based template which requires ios 10.6 for some forsaken reason)
Any help would be appreciated!
