Go to Post Life isn't fair. There's always luck involved. Welcome to the real world. :) - Exla357 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 22-09-2014, 18:59
YPatrick's Avatar
YPatrick YPatrick is offline
FRC #1671 (Buchanan Bird Brains)
Team Role: CAD
Rookie Year: 2013
YPatrick will become famous soon enough
Designing a Snail Drop CAM
Hey Everyone,
I'm noticing a lot more FRC teams have been using snail cams for shooters and other continually reloading mechanisms, but I can't think of any ways of making a progressive CAM in CAD. Any ideas? I'm talking about these:
http://www.technologystudent.com/images5/snlcam3.gif
Unread 22-09-2014, 19:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Designing a Snail Drop CAM
You can create spirals easily using polar coordinates.
See attached examples.
Also check out these threads:
http://www.chiefdelphi.com/forums/sh...93#post1330693
http://www.chiefdelphi.com/forums/sh...40#post1326440
One nice feature of a cam is that, with a little math, you can derive the equation (or generate a lookup table from experimental data) so that the torque required to drive it remains constant as it is pulling back the arm. Then you can use that equation to cut out the cam.
ID:	17329  Click image for larger version
ID:	17330  Click image for larger version
Unread 22-09-2014, 22:43
YPatrick's Avatar
Team Role: CAD
Rookie Year: 2013
Thanks, I'm trying this in my CAD software right now.
Unread 22-10-2014, 11:33
evand4567's Avatar
evand4567 evand4567 is offline
AKA: Evan
FRC #2022 (Titan Robotics and Team Neutrino)
Rookie Year: 2012
evand4567 is an unknown quantity at this point
You might be able to do it using the Design Accelerator in Inventor. If not, you can create the function and plot it in a sketch.
Unread 23-10-2014, 20:10
DonRotolo's Avatar
Back to humble
FRC #0832
I've created a cam in Excel and exported it to my CNC program for cutting.
As Ether mentioned, the goal was fairly constant torque on the motor turning the cam.
