Better Lucky than Good - TORC Autonomous
http://youtu.be/rOIcpDOKF78
At Kettering Kickoff last week, we showed off some new autonomous tricks. The new sequence is drive slow, if goal is not hot, shoot high, miss shot, catch rebound, now goal should be hot, shot and make it. Drive team ran two ball code with one ball. File it under better lucky than good. TORC is in blue bumpers middle bot. |
Re: Better Lucky than Good - TORC Autonomous
Wow! Spread the luck!
You say that you drive slowly if the goal is not hot. Therefore I assume you have image processing. If so, why drive at all if it isn't hot? Wouldn't it be better if you wait until it is hot and then drive?
Drive slowly. if(goal!=hot) { shoot miss catch shoot } |
In that particular case, we ran our 2 ball autonomous but without putting the second ball behind the robot.
Sequence for 2 ball auto: put arm down drive forward pulling second ball along shoot 1st ball within 1st 5 seconds of auto load second ball shoot 2nd ball in 2nd 5 seconds of auto Normally, we wouldn't shoot again after the 1st ball because we have ball detection that would prevent a dry fire. After we fired the 1st ball and missed, the robot was just sitting waiting for autonomous to end. When the missed ball landed in the robot, we sensed we had another ball and after a little settling time we shot the second ball just as auto was ending. We do have a 1 ball auto with hot detection but decided not to use it for that particular match. Last edited by Shu : 10-16-2014 at 07:58 AM. |
