Go to Post anything that craves Mountain Dew is definitely intelligent enough to be dangerous. - IMDWalrus [more]
View Poll Results: Do you think 8 MINI-CIMS allowed would be a good idea?
Yes, I'ld love to see what people come up with using 8 MINI-CIMS. 46 41.07%
No, I like the motor rules the way they are! 66 58.93%
Voters: 112. You may not vote on this poll
Unread 26-09-2014, 14:58
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Rookie Year: 2011
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Exclamation 8 MINI-CIM SWERVE
Would any one else like to see (8) MINI-CIM motors allowed so the swerves can be on par with the (6) CIM tank drives?
Looks like an 8 MINI-CIM motor swerve drive would be very close to power and weight of 6 CIM motor 6WD/8WD.
POWER
CIM 6 x 337 watts = 2022 watts total power
MINI-CIM 8 x 230 watts = 1840 watts total power
Within 10% instead of down 50%.
WEIGHT
CIM 6 x 2.80 lbs = 16.8 lbs
MINI-CIM 8 x 2.16 lbs = 17.28 lbs
Seems like the current rules favor a 6 CIM tank over a 4 CIM swerve for acceleration and top speed. I personally would like to see this somehow corrected. Maybe separating BAG motors from the MINI-CIM motors and a allowing 8 MINI-CIM motors?
This could be calculated by adding the watts of all motors used with a not to exceed. Or even more simply a CIM=1 and a MINI-CIM=.66 or .75 and a maximum of 6 when added up.
What's your thoughts?
Unread 26-09-2014, 15:22
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: 8 MINI-CIM SWERVE
I'm not averse to the rule change, especially if limiting total power is the aim of the rules. 8 mini cims ~= 6 cims.
The performance gain might not meet your expectations though. A tank drive will be better at putting that power to the ground (in a straight line anyway). When accelerating or pushing, the bot will "squat" toward the back wheels. As the weight comes off the front wheels, the force they can apply may become traction-limited, rather than power-limited. In a tank drive the front wheels and back wheels are chained together, so the weight distribution doesn't matter, but in a swerve drive, those front motors may spin uselessly.
The math on how big an effect this is is left as an exercise for the reader
Unread 26-09-2014, 15:56
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
This kind of formula would even allow the GDC to dial back the maximum total power equivalent (TPE) if they wanted to (as some commenters propose). Hypothetically backing down the limit from 6, to say, 5, would result in *less powerful bots*, but still allow teams to use the following combinations (for example):
4-Cim (divisible by 2 and 4, TPE = 4)
6-Mini-Cim (divisible by 2, 3 and 6, TPE = 4.5)
2-Cim + 4 Mini-Cim (divisible evenly by 2 only, TPE=5)
8-9015 motors (divisible by 2, 4, and 8, TPE=~4.8)
Unread 26-09-2014, 17:44
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
How would you fit two motors inside a wheel?
Unread 26-09-2014, 19:17
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You'd use one to drive the wheel and one to turn the module.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 26-09-2014, 19:27
But that would not allow you to have similar power to a 6 cim tank drive, which is the point of the 8 mini-cim argument right? (I might be missing something) You could have more than 4 modules in order to match the 6 cim power I guess.
Unread 26-09-2014, 19:32
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
You could do a swerve using those fancy mercury free mechanical slip rings and put the motors where they belong (external to the module), and easily do 2 per wheel.
Unread 26-09-2014, 19:38
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
6 inch wheels. Baxter Bomb Squad already uses them and it would give you 1/2 inch of clearance on ether side. How the gearing would work is a totally different story.
But THIS
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 26-09-2014, 20:15
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Originally Posted by Max Boord View Post
But this nuttin'. Try one of THESE! (Just swap the FPs for more CIMs.)
It's not about more/less points of contact with the ground, or about how much power you can put into the drivetrain, or how much traction a given wheel has. It's the balance of all of the above. I don't think that adding two more motors will do all that much--just make ya more likely to be traction-limited instead of torque-limited.
Past teams:
Unread 26-09-2014, 20:24
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Rookie Year: 2011
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Look at what happen with the change from 4 cim drives to 6 cim drives. They are classes of there own.
Unread 26-09-2014, 20:31
Upgraded.
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 26-09-2014, 21:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
2 extra motor controllers, 2 fewer available 40A ports on the PDB - 8 Mini CIMs vs 6 CIMs is a lose IMO.
Unread 26-09-2014, 21:15
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
For me too, but If another team decides they would rather have all 40A circuits going to the drive, and only use lower power circuits for the rest of the bot, why should the rules keep them from making that trade-off on their own?
Unread 26-09-2014, 22:27
JesseK's Avatar
FRC #1885 (ILITE)
Drive trains are easy to build. Without understanding the fundamentals, drive trains are very hard to perfect as part of a greater robot with other mechanisms. I feel that increasing the amount of power through to the drive trains is a cop-out low & mid-tier teams who don't bother to try to perfect their drive train. I'd much rather the GDC limit total electric power through the drive train if there were any rule changes in that respect. It would force the trade-offs to be actual engineering decisions rather than "BIGGER IS BETTER RAWR!1".
On top of that, I feel that anyone who mentions 6 CIMs as what led to success in an anecdote should have a gigantic caveat stickied across their post. I don't know about the exact wording, but perhaps it could say something like
Dear FRC participant, 6 CIM drive trains (or 8 MiniCIMs) may lead to some nice zippy acceleration if you "like to go fast". Yet here are some side effects you should consult your robot engineers about:
  • Your drivers keep getting penalties for high-speed ramming
  • Your robot "passes out" for about 30 seconds after getting into a pushing match
  • Your batteries from last year's competition no longer hold a charge for the entire match
  • Your other motor-driven subsystems are noticeably slower towards the end of a match
  • The tread constantly strips off of your wheels when merely grazing another robot
  • Your aluminum output shaft shears
  • The chains snap apart at the master link or eat the teeth off of the sprockets after a quick reverse
These were witnessed, BTW.
Full disclosure, 1885 took a beating by powerful drivetrains at champs this past year. Getting double-teamed as a single-speed 11ft/s drive train got very aggravating very quickly. We endured, had some great matches and I know what to do for next year. We even had our very first actual zero-maintenance and very agile drive train this year across 4 competitions. Hopefully I've presented this in such as way that shows more thought has gone into it based upon several years of drive train design experience, rather than a single competition's worth of bias.
  #15   Spotlight this post!
Unread 27-09-2014, 01:18
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
4464 used a 6-CIM drive last year, and I'd be the first to add caveats when we talk about the success it brought us (I've detailed the problems we encountered several times on these boards), but it is important to recognize that every single problem you've mentioned is something that can be either mitigated or avoided completely with proper diligence.
Yes, a young, inexperienced team naively going "MORE IS BETTER!" and mindlessly adding motors to their drive can easily do more harm than good, and designing a 6 CIM drive in a way that doesn't run into the mentioned problems is nontrivial (we had to swap our gearing before champs last year, and it wasn't because we hadn't put a lot thought into the gearing we originally had), but I don't think that every 6 CIM success story is necessarily ignoring or downplaying the negatives, or overstating the positives.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
