Go to Post JVN, Captain Mechanical Engineer, Mr. "Software is evil", has supported the CMU camera. I'm speechless. What's next? Copioli designing in imperial? - Karthik [more]
View Poll Results: Do you think 8 MINI-CIMS allowed would be a good idea?
Yes, I'ld love to see what people come up with using 8 MINI-CIMS. 46 41.07%
No, I like the motor rules the way they are! 66 58.93%
Voters: 112. You may not vote on this poll
Unread 26-09-2014, 14:58
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Rookie Year: 2011
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Exclamation 8 MINI-CIM SWERVE
Would any one else like to see (8) MINI-CIM motors allowed so the swerves can be on par with the (6) CIM tank drives?
Looks like an 8 MINI-CIM motor swerve drive would be very close to power and weight of 6 CIM motor 6WD/8WD.
POWER
CIM 6 x 337 watts = 2022 watts total power
MINI-CIM 8 x 230 watts = 1840 watts total power
Within 10% instead of down 50%.
WEIGHT
CIM 6 x 2.80 lbs = 16.8 lbs
MINI-CIM 8 x 2.16 lbs = 17.28 lbs
Seems like the current rules favor a 6 CIM tank over a 4 CIM swerve for acceleration and top speed. I personally would like to see this somehow corrected. Maybe separating BAG motors from the MINI-CIM motors and a allowing 8 MINI-CIM motors?
This could be calculated by adding the watts of all motors used with a not to exceed. Or even more simply a CIM=1 and a MINI-CIM=.66 or .75 and a maximum of 6 when added up.
What's your thoughts?
