Go to Post You need to stay on top of your classes or you will be back as a returning freshman on next year's team. - [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-09-2014, 10:38
Anthony4939 Anthony4939 is offline
None #4939
Anthony4939 is an unknown quantity at this point
Wiring Kit
We are looking at several wiring kits.
Should we opt for Futaba J connectors or universal connectors?
Also, looking to stock up on wire. What gauges are most common? 16, 18, 20?
Looking battery wire and servo wire.
Unread 27-09-2014, 10:51
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Wiring Kit
Get the universal connectors. They will work with everything, the J-style doesn't necissarily.
Most common wire gauges:
6AWG for battery leads and main breaker
10AWG or 12AWG for most motor power distribution. 10AWG will have less resistance, which can really add up, but also weigh more. There is also this cool technology available in 12AWG which makes a big difference in moving components, and routing wire in tight spots.
18AWG for lower current components
22AWG servo wire.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 27-09-2014, 11:16
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Wiring Kit
Originally Posted by Joe G. View Post
6g for battery leads and main breaker
10g or 12g for most motor power distribution. 10g will have less resistance, which can really add up, but also weigh more. There is also this cool technology available in 12g which makes a big difference in moving components, and routing wire in tight spots.
18g for lower current components
22g servo wire.
I was really confused as to why you were measuring your wire in grams for a moment
But more seriously, that's pretty much stock standard. You can also use 14AWG for 30A circuits [Standard 2014 vs 2015 rule warning], but we generally only use 12AWG or 18AWG. We actually prefer 26AWG for servo wire, since they're generally only taking TTL signals, the extra resistance isn't an issue and we find it's easier to insert into the housings.
Also whenever possible get bonded/zip cable such as this, it makes your wiring much cleaner and easier.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 27-09-2014, 11:20
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: Wiring Kit
We used 26AWG servo wire this year and won't be doing so again. We failed quite a few PWM crimps due to wire either slipping out or repeated bend stresses. May have had something to do with the strand count of the wire we used as well, but moving forwards, we'll take the extra reliability insurance.
Unread 27-09-2014, 11:28
timytamy's Avatar
AKA: Tim
Rookie Year: 2010
Re: Wiring Kit
That's interesting, do you have a P/N for the wire/crimps/crimper that you used? The only failure we had this year was a student getting a bit too excited over cutting cable ties :| However this year we had the luxury of set-and-forget electronics, most cables were installed once in their permanent position, so they weren't stressed too much.
Tim W
Sydney, Australia
Unread 27-09-2014, 11:37
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: Wiring Kit
We use all the standard Hansen Hobbies stuff:
Crimper
Terminals
Wire
We had used the exact same crimper and terminals for a few years, and most of the failures took the form of bending failure of all wire strands, so we blame the wire. I don't know off the top of my head the wire that 1687 used before this year (I know it was a lower gauge), but my team plans to use this stuff moving forwards, although we may experiment with other gauges of the high-strand stuff.
The vast majority of failures were of sensor leads related to our shooter gearbox, which we removed for maintenance a few times, and between each event as part of our withholding allowance. Wires that didn't need to be touched after installation such as victor PWMs fared much better.
Unread 27-09-2014, 11:53
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Wiring Kit
Also consider using your DigiKey voucher for this (assuming there is one this year):
PWM/signal cable supplies:
WM2517CT-ND - CONN TERM MALE 22-24AWG TIN
WM2510-ND - CONN TERM FEMALE 22-24AWG TIN
WM2800-ND - CONN HOUSING 2POS .100 SINGLE
WM2801-ND - CONN HOUSING 3POS .100 SINGLE
WM5354-ND - CONN HSG 2POS .100 SINGLE VER D
WM2872-ND - CONN HOUSING RCPT .100 3POS
WM9999-ND - TOOL CRIMP 14-24AWG UNIVERSAL
We use 22ga 2/3 conductor stranded security system wire for PWM cables. If you hit up a local security system/low voltage installer, and are _specific_ about what you ask for (you don't want ethernet cable as it is solid), you can get enough for several years for free from their scrap.
Be sure you are using the correct wire, and are crimping properly.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 28-09-2014, 04:28
timytamy's Avatar
AKA: Tim
Rookie Year: 2010
Re: Wiring Kit
Crimper
Terminals
Wire
We used exactly the same setup, except we used this crimper, regardless of what gauge you do use in future I'd recommend you invest in it or something similar. As a rule we don't allow any crimps on the robot that are not ratcheted, as it is much harder to guarantee a good crimp between students.
@OP: I'd recommend you purchase this kit, and then some extra wire (with a gauge of your choice), terminals and housings.
In terms of pneumatics, you should have a look at the kits from AndyMark here. Personally, we prefer 24V Solenoids mainly because they are easier to source in Australia, but also we have a large stock as it's what usually comes in FIRST Choice. Also the 24V supply was guaranteed in the cRIO control system, but the 12v wasn't. AndyMark however only sells the 12V version. Regardless of which you go with, it's a good idea to pick one and stay with it.
Tim W
Sydney, Australia
Unread 28-09-2014, 08:59
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Wiring Kit
The same is true in the 2015 control system.
Unread 28-09-2014, 16:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Wiring Kit
Are we sure the PCM doesn't have a regulator? We know there's an booster because the 24v supply is created inside the PCM, instead of the PDB like the previous system.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 28-09-2014, 17:13
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Wiring Kit
I confirm that the PCM's 12v solenoid output is just the current battery voltage.
Unread 27-09-2014, 13:17
None #4939
Re: Wiring Kit
Thanks for the replies everyone. We are a second year team and are looking to start building a supply. The wire kits were going to be ordered from Hansen Hobbies.
Any suggestions for a good pneumatics supply kit?
