Go to Post A few months from now I'll be walking to school and then I'll suddenly be attack by a rogue robot trying to feed me a golden ball or something wont I? - Marcel [more]
Unread 27-09-2014, 23:39
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Legal Wiring
Would using 2 conductor stranded wire that is covered with a grey insulator be legal? The rules say that the wires must be colored but does that mean the entire wire or just the ends where it connects to the components of the robot.
http://www.libertycable.com/products...onductor-cable
This is the type of wire I am talking about. I could always remove the grey but to keep things simple it'd be nice to keep it on.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 27-09-2014, 23:53
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Re: Legal Wiring
I don't know what official judgement would say, but we typically run wires together in nylon braid and that covers the color markings. Red and black are always clearly visible at the ends of the wires. We've not had an issue with inspection and I would think that if sufficient color shows it wouldn't be an issue. Again, I can't say for certain though. A team that has tried this in the past will probably be able to better answer your question. If your goal is to keep wires paired, you may want to look at this. It's the same thing we use on our robots.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 28-09-2014, 00:18
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Legal Wiring
Personally, I don't see anything wrong with it... the wires are clearly color coded inside the outer jacket, and that coloring should be obvious at either end. Additionally, if you need to cut or splice the wire in the middle for anything, you'll have to expose the color coding in order to do so. This is really no different conceptually than using a nylon wire mesh sleeve, and I know teams have used that without issue for ages. But that's just my opinion, which means absolutely nothing at your event!
Ask on the Q&A when it opens in about 100 days. Then you can be sure the answer is consistent across all events you go to.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 28-09-2014, 10:07
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Legal Wiring
Tim,
The grey is referred to as "jacket" and this wire is legal on FRC robots where color coding is required. There is a weight disadvantage though. The jacket is often filled with clay and can be hydroscopic meaning it will absorb moisture from the air. While this amount is small, added to the additional weight of the jacket might pick up more weight than you want. The zip cord available from places like MCM Electronics works as well, doesn't carry any extra weight and is easier to prepare. Check the varieties and quantity here...
http://electronics.mcmelectronics.co...p+cord&x=0&y=0
I currently use the jacketed variety for feeding speakers in the studios here.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 28-09-2014, 23:55
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Legal Wiring
It is legal. We've been making PWM cables this way for 10 years. It does weigh a little more but we like protecting the conductors.
Fast, cheap or working - pick any two!
