Go to Post This is why I love this game. It's like high speed chess with flashing lights and lots of noise. - Karthik [more]
Unread 01-10-2014, 13:16
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
Rookie Year: 2012
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Constant Orange Light on Spike
Hi guys,
Our compressor isn't running when we enable to robot, below is everything I've noticed:
Light on the Spike stays orange when we enable the robot
Light on the sidecar turns on when we enable
PWM cable has been switched out many times, still doesn't work
20 amp breaker in spike and pd board, neither breaker trips when we enable
Compressor works when bypassing the spike
We've been running the same compressor code since St. Louis, it worked at a previous off season, so we are very certain it is not a code problem
We have an off season event this friday, so any help is appreciated.
Thanks,
Dylan
Unread 01-10-2014, 13:20
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Constant Orange Light on Spike
Is your pressure switch connected to the digital sidecar?
Unread 01-10-2014, 13:22
Team Role: Driver
Rookie Year: 2012
Yes the pressure switch is connected to the digital side car. We've also tried various spikes and we can't get it to work.
Unread 01-10-2014, 13:37
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Is the PWM cable on the spike properly seated?
Unread 01-10-2014, 13:41
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
This times all of it. I have helped trouble-shoot so many "my compressor won't run" problems that traced back to this, especially when teams insisted that it was seated properly. It is really easy to mess up.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 01-10-2014, 13:47
Team Role: Driver
Rookie Year: 2012
Okay, I'll redo the PWM cable once I get a chance, and the bad seating would be consistent with how the problems reoccur when we change the spike/pwm.
Unread 01-10-2014, 14:44
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Do you have a replacement Spike. I have seen them just stop working.
Unread 01-10-2014, 15:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Many times, if your PWM wire prongs are straight they may not make contact. We bend them slightly outward so they exert a bit of pressure in the connection. It helps keep them from falling out as well, but we still retain them with other methods because they just don't stay in.
Unread 01-10-2014, 18:06
Team Role: Driver
Rookie Year: 2012
We changed the PWM cable, bent out the prongs, still doesn't work. Also previously when we replaced the Spike with a brand new one it worked briefly, but after we turned it off, tied it down, and re-ran it, it no longer worked.
Unread 01-10-2014, 18:32
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Something I have found is that If the Vex spikes are not working because of the loss PWM. I suggest is to test an old IFI Spike. The connection seems to be more solid.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 01-10-2014, 21:48
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
Rookie Year: 2010
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Ditto. The VexPro spikes have given us a problems many times, like the PWM not being seated properly and for some reason the fuse is always either so tight it can't be pulled out ever or really loose. The old IFI spikes have never given us an issue.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 01-10-2014, 13:38
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Given that the light on the DS turns on, that says the DS is getting the activation signal, which rules out the pressure switch or code.
Getting a PWM correctly seated in a Spike or Victor is an art. I suspect that is your problem, despite the fact that you tried multiple PWM cables. It may be helpful to get help from a local team that has the touch, if the problem persists.
One other thing I didn't see in your list is measuring the signal from the DS, although I don't think it is likely that this is the problem.
