| Thread Tools |
Rating:
Display Modes |
[FRC Blog] - NASA Grants and Something New for 2015
http://www.usfirst.org/roboticsprogr...g-New-for-2015
Re: [FRC Blog] - NASA Grants and Something New for 2015
#FrankTooStrong |
I don't think field size will change because of the andymark field being approved for 2015... *MAYBE
*Wonder if we'll be seeing a big change in strategy similar to assists this year. |
Number of teams on an alliance: 2v2? like FTC and old FRC? Could be interesting.
Number of alliances in a match: Unless they make it 2x2x2x2, would probably make modifying the field really expensive. Match length: They can change it a bit, but there's event scheduling issues. Bumper rules: These have changed frequently. Not that exciting. Field surfaces: Low-friction surface, anyone? Robot size: I don't see this changing too drastically either. Last edited by nfhammes : 10-01-2014 at 03:21 PM. |
A little annoying when trying to go there and I just get the same CD page over and over ![]() |
I know they may have other reasons for this but 4 team alliances gives more credence to why there were 4 team alliances at World Champs last season.
Maybe early premonition? |
Maybe its how they plan to fit more teams at the championship without adding more fields?
#10
I'm trying to imagine the logistic of fitting 8 robots onto one field without changing the size limitations on the robots again. Especially if we see some field obstacles added to the field again. That would be one crowded field.
#12
Basically, your pit time is ((Event_Teams/Match_Teams ) - Queued_Matches) * Cycle_Time. Queued_Matches is typically 2. Cycle_Time is usually somewhere around 8. ((40/6)-2) * 8 ~= 32 ((32/6)-2) * 8 ~= 24 ((40/8)-2) * 8 ~= 24 ((32/8)-2) * 8 ~= 16 Idk, I would like a little more time to fix my bot than 16 minutes. |
#13
At least with defensive bots as a fourth spot for queuing on either side, queuing at most events wouldn't be impacted too significantly. But loading-on, even if each alliance queues in on one side, and isn't disrupted by robots getting off, would add some to match cycle time. Which is admittedly less of an issue when each match gives 8 plays, rather than 6.
#14
We talk each year when game hints come out about how the hint could mean big changes to field shape, alliances ETC. I think this is confirmation that something along those lines is coming so there's definitely cause for excitement!
Expanded championship, expanded alliance size? More teams, more matches, more teams in each match? |
#15
