Hello Chief Delphi,
We are FTC Team 8660, the Charging Champions. We are a rookie team who needs help programming the Logitech controller provided by FIRST. We are using RobotC. We were able to configure the Samantha module to the router and have made many, many attempts programming it but we're unable to to get it to work. After searching on online blogs, tutorials, and videos for a long time, we were unable to find the answers, so we came here seeking advice. We also cannot get the joystick to work, even by wired connections.
All help is appreciated. Go FTC Teams!!! Sincerely, Charging Champions FTC Team 8660 Last edited by FRC Team CC : 04-10-2014 at 12:22. Reason: Better Word Choice |
Re: [FTC]: Need Help Programming Joystick via Samantha
Here is our Teleop code from last year... see if this helps. Shorter version below.
Code:
#pragma config(Hubs, S1, HTMotor, HTMotor, HTMotor, HTServo)
#pragma config(Sensor, S1, , sensorI2CMuxController)
#pragma config(Motor, mtr_S1_C1_1, right, tmotorTetrix, openLoop, reversed)
#pragma config(Motor, mtr_S1_C1_2, left, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C2_1, tower, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C2_2, none, tmotorTetrix, openLoop)
#pragma config(Motor, mtr_S1_C3_1, claw, tmotorTetrix, openLoop, reversed)
#pragma config(Motor, mtr_S1_C3_2, flag, tmotorTetrix, openLoop)
#pragma config(Servo, srvo_S1_C4_1, Brake, tServoStandard)
#pragma config(Servo, srvo_S1_C4_2, LeftFlap, tServoStandard)
#pragma config(Servo, srvo_S1_C4_3, RightFlap, tServoStandard)
#pragma config(Servo, srvo_S1_C4_4, Block, tServoStandard)
#pragma config(Servo, srvo_S1_C4_5, servo5, tServoNone)
#pragma config(Servo, srvo_S1_C4_6, servo6, tServoNone)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
#include "JoystickDriver.c" //Include file to "handle" the Bluetooth messages.
void initializeRobot()
servoTarget[Brake] = 65;
servoTarget[RightFlap] = 241;
servoTarget[LeftFlap] = 18;
servoTarget[Block] = 237;
return;
task main()
initializeRobot();
waitForStart(); // wait for start of tele-op phase
while (true)
getJoystickSettings(joystick);
if(joy1Btn(7))// claw Up
motor[right] = joystick.joy1_y2/4;
motor[left] = joystick.joy1_y1/4;
else
motor[right] = joystick.joy1_y2;
motor[left] = joystick.joy1_y1;
motor[tower] = joystick.joy2_y1;
//****************** DRIVER 2 (James) ***************************
if(joy2Btn(6))// claw Up
motor[claw] = 128;
else if(joy2Btn(8))// claw Down
motor[claw] = -128;
else
motor[claw] = 0;
if(joy2Btn(2))//flinger
servoTarget[Block]= 170;
else
servoTarget[Block]= 237;
//****************** DRIVER 1 (Jacob) ***************************
if(joy1Btn(4))// flag up
motor[flag] = 100;
else if(joy1Btn(3))// flag down
motor[flag] = 50;
else if(joy1Btn(2))// flag down
motor[flag] = -100;
else
motor[flag] = 0;
if(joy1Btn(5)) //Right FLAP
servoTarget[LeftFlap] = 80;
else
servoTarget[LeftFlap] = 180;
if(joy1Btn(6))// Left FLAP
servoTarget[RightFlap] = 146;
else
servoTarget[RightFlap] = 47;
//*********************** BOTH DRIVERS **************************
if(joy1Btn(1)&joy2Btn(1))// baton mover
servoTarget[Brake] = 97;
else
Code:
return;
task main()
initializeRobot();
while (true)
All of our archived code from the last 2 seasons can be found at: http://www.4211thebombers.org/UsefullLinks.html
The "Team 4211's Block Party Code" and "Team 4211's Ring it Up Code" links contain all the autonomous and telop code that we ran at competitions. They have examples of various techniques and strategies for controlling the robot in telop and autonomous, including how to separate the joystick inputs into different threads to allow faster response times. To more directly answer your question, here is a program with all the basic telop components you need along with various control schemes for driving a robot and for moving a servo. Just uncomment a section you want to try and it will work on a robot. Code:
#pragma config(Hubs, S1, HTMotor, HTServo, none, none)
#pragma config(Motor, mtr_S1_C1_1, Right_Drive_Motor, tmotorTetrix, openLoop, reversed)
#pragma config(Motor, mtr_S1_C1_2, Left_Drive_Motor, tmotorTetrix, openLoop)
#pragma config(Servo, srvo_S1_C2_1, exampleServo, tServoStandard)
#pragma config(Servo, srvo_S1_C2_2, servo2, tServoNone)
#pragma config(Servo, srvo_S1_C2_3, servo3, tServoNone)
#pragma config(Servo, srvo_S1_C2_4, servo4, tServoNone)
#pragma config(Servo, srvo_S1_C2_5, servo5, tServoNone)
#pragma config(Servo, srvo_S1_C2_6, servo6, tServoNone)
#include "joystickdriver.c";
// put the code to initialize servo positions in here
// don't put code to move motors in here as that can lead to a DQ
task main()
initializeRobot(); // initialize robot
waitForStart(); // waits for FCS to start the match
while (1)
getJoystickSettings(joystick); // get new message from joystick
// 3 common drive control schemes for differental drive robots are below
/* delete this line and line 29 to run this drive mode
// drive the robot in tank drive style with the joysticks
motor[Left_Drive_Motor]=joystick.joy1_y1;
motor[Right_Drive_Motor]=joystick.joy1_y2;
/* delete this line and line 61 to run this drive mode
// drive the robot with 4 buttons
if (joy1Btn(4)) // drive forward when button 4 is pressed
motor[Left_Drive_Motor]=75;
motor[Right_Drive_Motor]=75;
else if (joy1Btn(2)) // drive backwards when button 4 is pressed
motor[Left_Drive_Motor]=-75;
motor[Right_Drive_Motor]=-75;
else if (joy1Btn(1)) // turn left when button 1 is pressed
else if (joy1Btn(3)) // turn right when button 2 is pressed
else // stop when no button is pressed
motor[Left_Drive_Motor]=0;
motor[Right_Drive_Motor]=0;
/* delete this line and line 107 to run this drive mode
// drive the robot with the tophat on the left side of the controller
switch(joystick.joy1_TopHat)
case 0: // drive forwards when top hat is pushed forwards
break;
case 1: // drive right forwards when top hat is pushed front right
break;
case 2: // turn right when top hat is pushed right
break;
case 3: // drive back right when top hat is pushed back right
break;
case 4: // drive backward when top hat is pushed back
break;
case 5: // drive back left when top hat is pushed back left
break;
case 6: // turn left when top hat is pushed left
break;
case 7: // drive front left when top hat is pushed front left
break;
default: // stop the robot when no top hat direction is pressed
break;
// 3 common servo movement controls
/* delete this line and line 132 to run this servo control mode
// move a servo with the joystick
servo[exampleServo]=joystick.joy1_y1;
/* delete this line and line 146 to run this servo control mode
// move a servo to a postition when a button is pressed
if (joy1Btn(5))
servo[exampleServo]=0; // change the '0' to whatever position you need when the button is pressed
else
servo[exampleServo]=255; // change the '0' to whatever position you need when the button is released
/* delete this line and line 162 to run this servo control mode
// move a servo to a forward/backward like a motor when a button pair is pressed
if (joy1Btn(5))
servo[exampleServo]=ServoValue[exampleServo]+1; // increase the '1' to make the servo change its position faster
if (joy1Btn(7))
servo[exampleServo]=ServoValue[exampleServo]-1; // increase the '1' to make the servo change its position faster
You should check out the youtube videos posted by the Robogamers. The channel is RobogamersTV
https://www.youtube.com/user/robogamersonline Watching their videos helped us a lot. They have one specifically on joystick control programming. https://www.youtube.com/watch?v=3HF31q2mnfA The Anderson wiring will probably help as well. https://www.youtube.com/watch?v=M1FsxbLcM0w Hope this helps. |
