Go to Post Yes, I think we can all agree that bad people suck. - Joe Johnson [more]
Unread 16-10-2014, 14:40
bmammen's Avatar
bmammen bmammen is offline
AKA: Brent Mammen
FRC #5801 (Inspire)
Rookie Year: 2014
bmammen is an unknown quantity at this point
Mechanical limit switches - acceptable practice?
We were wondering if it’s an acceptable practice to have a second normally closed limit switch wired in line with a motor and sitting just a little longer in the throw, past the electrically monitored limit switch as a safety precaution?
The reason that I ask is that last season we had two instances where our software controlled limit switch either didn’t work or was physically knocked off center causing a very strong bag motor with planetary gearbox to bend and break our launching mechanism as it didn’t shutoff the motor at the end of the throw.
Any suggestions?
Unread 16-10-2014, 14:50
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mechanical limit switches - acceptable practice?
Any suggestions?
FRC legality aside, a few technical questions:
What motor controller were you using?
About the software you were using to detect the switch state: Was this an interrupt service routine or a polled task? If polled, at what frequency?
About the software you were using to react to the limit switch state: Was this an interrupt service routine or a polled task? If polled, at what frequency?
About the limit switch actuating lever: did you add a flexible extension to prevent permanent bending of the lever?
and finally:
What's the current rating on the limit switch you plan to put in the power line going to the motor?
Unread 16-10-2014, 14:56
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
The other question I'd ask is, is this a more-than-one-use mechanism? Because once that limit switch kills power to the motor....
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 16-10-2014, 14:57
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Driver flails on the joysticks until the arm moves enough to lose contact!
Unread 16-10-2014, 14:58
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
Rookie Year: 2014
Actually I'd not like to put FRC legality aside, if it's against the rules then we don't want to do it.
Our motor controllers are Talon SR's and not Jag's with CAN controlled limits, and to focus on one of the scenario's - lets go with the switch was physically damaged during a match (and it was), so we can leave programming out of the discussion for right now unless the thinking is to add another monitor in addition to the limit switch.
Yes the normally closed limit switch would need to be rated for the current draw of the bag motor.
Just wondering if this is possible and legal.
Thanks for the reply!
Unread 16-10-2014, 15:00
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
Rookie Year: 2014
Yes, the limit switch would be a safety mechanism and the robot would be done for the match however it could be fixed much easier than replacing a mangled launching assembly.
Unread 16-10-2014, 15:07
Ether's Avatar
Rookie Year: 1969
Do you know with acceptable certainty why the switch got damaged? I ask because in your original post it sounded like you don't know why:
Before you fix something, it's worthwhile to make a concerted effort to figure out why it failed. Software could be the cause. Or lack of a flexible extension on the actuation lever. Or improper mounting of the switch.
Unread 16-10-2014, 15:13
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
Rookie Year: 2014
Understandable, but similar to the reasoning behind breakers on the PDB - there could be a plethora of failures/mistakes/accidents and therefore never a bad idea to provide a safety mechanism to help narrow the scope of imperfection.
Unread 16-10-2014, 15:15
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Not necessarily. If the arm contacted a spring (a cushioned hard-stop is a good idea anyway) that was able to push the arm off the switch after the switch cut power to the motor, you could reset everything. That's just an example.
Or this...
This, however, is the most important part.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 16-10-2014, 15:20
Ether's Avatar
Rookie Year: 1969
If your root-cause failure analysis reveals that it's a software timing issue (your software as designed can't reliably respond fast enough to the limit switch), you might want to consider using a pot instead of a limit switch as your primary means of preventing motor overtravel. That would give your software a lot more time to respond and slow the motor down.
Unread 16-10-2014, 15:24
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
Rookie Year: 2014
Awesome, thanks for the input! We'd talked about adding a pot and that sounds like a good option.
Unread 16-10-2014, 15:27
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
A limit switch in the motor power pathway sounds like it would violate last year's R50 and primarily R53, but a robot inspectors advice is more valuable on questions such as these.
R53
CUSTOM CIRCUITS shall not directly alter the power pathways between the ROBOT battery, PD Board, motor controllers, relays, motors, or other elements of the ROBOT control system (items explicitly mentioned in R64). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, if the effect on the ROBOT outputs is inconsequential.
Unread 16-10-2014, 15:42
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I agree with Mark that it isn't legal to place a limit switch inline with a motor.
We've typically chosen two options from the following list:
  • Limit Switch with software control
  • Potentiometer or Encoder with PID control and soft limits
  • Current sensor
  • Mechanism robust enough that it doesn't matter
Another option is to use the limit switch inputs on the jaguars, which will operate faster then your software and won't get commented out accidentally.
Unread 16-10-2014, 17:04
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Joe stole my comment about using Jags.
Anyway, as much as I like to rag on the software guys, Limit switch failures are almost always mechanical & how they actually stop the motor is not the issue.
Anything that requires double protection like you are suggesting, you want to separate the modes of operation as much as practical. Like using a feedback pot for normal posting & limit switch through a jag for the end points.
If you don't know what you should hook up then you should read a data sheet
  #15   Spotlight this post!
Unread 16-10-2014, 17:15
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
As others have said, this would be illegal. The intent, as I read it, of R53 is one of safety- we need to know that the robot will cooperate in a predictable way when connected to the field (for example the field says stop and the motors all stop), and we need to know that the components can handle the current the motor is going to be pulling. As such, this is something I could see as being something teams could lobby the HTC to change in future years- an appropriately rated limit switch wouldn't prevent the motor from stopping. The trick is finding an appropriately rated limit switch and ensuring inspectors can verify rinsing catch on fire while on the field.
Using the limit switch into a jag helps, as it takes it out of the programmers control. Additionally, we've always designed in a hard stop that would force the motor to stall before a mechanism ripped itself apart. This was also a good place for the limit switch, as the hard stop can help prevent a mechanical failure of the switch. Leave it stalled long enough and the mechanism might still year itself apart, but the hard stop gives you a small buffer for the code to respond to the limit switch.
Where possible, potentiometer or absolute encoders can also come in handy for helping to control a mechanism and limit its range of motion.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
