#16
Re: Traction Questions
I've always wondered about the traction of a larger diameter wheel compared to a smaller diameter wheel of the same width. I'd speculate it is more, since the curvature of the wheel approaches a straight line as the diameter approaches infinity. On squishy surfaces such as rubber and carpet, I can definitely see this making a difference.
It would be cool if AndyMark and VEX would step up to the plate to put this debate to rest once and for all, with some real scientific testing and published results In the end though, the real limiting factor in pushing is the internal resistance of the battery. |
#19
Here's some reading that went way over my head that may help understand friction between rough surfaces: https://workspace.imperial.ac.uk/med...20surfaces.pdf Quote:
You can simulate this without buying huge wheels, just use a pneumatic wheel and test it at varying levels of inflation, the under inflated wheel will likely have better traction in accordance with your theory. Last edited by themccannman : 27-11-2014 at 16:21. |
#20
Because aside from banebots and colsons, they have all the wheels.
#21
Cyber Blue tried that about 3-4 years ago, IIRC. I don't recall seeing any results, though I do think I heard a rumor about "'interesting' data" or something of that nature.
#23
Some testing from 2003:
http://www.chiefdelphi.com/media/papers/1381 http://www.chiefdelphi.com/media/papers/1382 |
#24
First of all, you're attempting to make an argument not based on physics, observation, or empirical data, but on intuition. You're basically saying "doesn't it seem like this would be harder?". You're creating a contrived example and implicitly asserting that the reason one technique is harder than the other is *entirely* friction. Intuition is not how to make an engineering argument. Second, I'm going to challenge the implicit assertion that the differences in force are due to friction entirely. A thin sheet of plywood is not flat - it's going to dig into the likely deformable surface it is under, such as carpet. For example, an edge could get caught in some carpet fibers. Putting a piece of plywood on its edge helps in part because there is so much less area for the plywood to "catch" the surface on. On a perfectly smooth surface, with smooth plywood (equal surface treatment on the edges and the flats), I don't believe there would be nearly as dramatic a difference. Finally, the scenario you described does not even relate to wheel traction! The contact patch of an ideal wheel that is not slipping is stationary relative to the ground. Static friction is the phenomenon in play in this case. When pushing a flat piece of wood across the floor, dynamic friction is a factor for a vast majority of the time you're pushing the wood. Dynamic friction can depend on surface area / contact patch much more than static friction does. |
#25
Here's an interesting thought experiment: On a dry sandy beach, which has more rolling resistance: 1) a bicycle with skinny racing tires, or 2) the same bicycle with fat balloon tires? Which has more traction? |
#27
If it's at some positive t, I'm going to be going with the skinny tires having more rolling resistance and more traction. But... Spoiler for But:
#28
Without hard data, this post really isn't worth jack... but I thought I'd add something I'd heard from teams before. For the specific case of roughtop tread, when using larger wheels, increasing width does not noticeably increase tractive force. As wheels get smaller, approach 4 inches diameter (sound familiar?), widening tread does begin to increase pushing power. My baseless conjecture is that as wheels get smaller, fewer rows of "spikes" on the roughtop tread are in contact with the carpet at the same time, putting more pressure on each individual row. At a certain point, the increased pressure really causes a row of spikes to "dig in" to the carpet. Adding more width to those wheels, while decreasing the pressure per unit area, allows more spikes to dig into the carpet, and once interlocking forces come into play surface area really does start to matter.
Someday, when there's time and money to be spared by whatever team I'm on, I'd love to test this hypothesis / idea / rumor with several tread types (roughtop, wedgetop, Colsons, AM HiGrips) |
