Go to Post I hope that kids will stop asking us if we build Battlebots and start asking us if we build Transformers. To that, I will answer with a resounding yes. - Madison [more]
Unread 18-10-2014, 23:17
phantomoperator phantomoperator is offline
FRC #3266
phantomoperator is an unknown quantity at this point
Motor suggestions for rubiks cube scrambler
Hello everybody! My name is phantomoperator and I just recently joined this forum to see if I could get some advice on how I should approach a very specific problem of mine.
A friend of mine and I are big into solving rubiks cubes and we both can currently solve them in less than 20 seconds. Here is a our dilemma. We hate scrambling the cubes. It takes us longer to scramble than actually solve the thing. What we want to do is a build an arduino powered scrambler where all we have to do is a press a button and have it scramble a cube.
Here is the problem with that. We dont know whether or not it would be best to use servos or stepper motors and even then, how to go about controlling them. We were leaning towards servos since they are small but they would have to be continuous rotation to work with our design.
Any thoughts or input would be greatly appreciated. thanks!
Unread 19-10-2014, 00:05
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
Rookie Year: 2011
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: Motor suggestions for rubiks cube scrambler
This is an interesting problem, to say the least. You're going to have to get potentiometers to ensure you are rotating 90 (or 180) degrees, instead of just a timer. You'll get more consistent results that way.
As for motors....I'm positive you could take apart an RC car and use the motors in them. I don't know the precise force required to turn a cube, but it isn't a lot, and a motor found in an electric toy should suffice. \
Best of luck!
If you really want to challenge yourself, you could make a robot that solves the cube
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 19-10-2014, 00:16
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Already been done, in LEGO--I remember seeing a video several years ago. Incidentally, that means that LEGO motors ought to be powerful enough. So would a heavy-grade hobby servo.
I'd go with a paired system: Stepper motor (which, in code, is simply told to go X steps, I think [I've never programmed one]) with a servo on whatever holds the cube to actuate jaws or what-have-you. NEMA-17 stepper motors are cheap and if they're powerful enough to drive a 3D printer, they're almost certainly powerful enough to drive a cube scrambler. And they're fairly small.
As far as programming, you'd essentially say: Let X, Y, and Z be random numbers, and let A, B, and C be motors. Drive A to X, B to Y, and C to Z, reset all numbers, repeat n times. Not sure quite how to implement that, though; it'll depend somewhat on your system.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-10-2014, 00:27
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Already been done, and then some: http://www.youtube.com/watch?v=X0pFZG7j5cE
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 19-10-2014, 01:36
faust1706's Avatar
Rookie Year: 2011
As for programming, here is how I would do it:
j = random number between n and m (I'd do 25 and 50)
for (unsigned int i = 0; i < j;i++)
generate a random number 1 to your total number of motors
then turn that motor either 90 or 180 degrees.
Unread 19-10-2014, 13:10
FRC #3266
I like the stepper motor idea. For our design we would need to control 5 motors. Our designs involves having little fixed jaws that fit around the center piece of the cube. We concluded that in order to fully scramble the cube we must turn 5 of the six faces.
Does any one have suggestions on a controller board?
Unread 20-10-2014, 01:57
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
How about a RAMPS 1.4 like they use for RepRap 3D printers.
That will handle 5.5 steppers...one is a split signal.
Unread 20-10-2014, 02:44
FRC #3266
That would work. Would I be able to control all of the motors independently?
Unread 20-10-2014, 02:58
techhelpbb's Avatar
Rookie Year: 1997
You have 5 independent drivers so yes.
If you watch any RepRap run you can see steppers moving at the same time independently.
The 0.5 stepper is usually used on dual Z printers like the Prusa.
You put 2 steppers on one driver each at half power but they move at the same time anyway and move the same axis in unison so that is fine. Still the others are independent in that setup.
Unread 20-10-2014, 11:35
FRC #3266
Awesome. That will work perfectly. Now my last question is how will we go about telling the motors what to do. Whaat we were hoping to do was have this be completely independent of a computer. We wanted to have a button that we could press and it would automatically generate a random scramble and mix up the cube.
Unread 20-10-2014, 11:48
techhelpbb's Avatar
Rookie Year: 1997
Populate RAMPS shield with stepper drivers (Pololu).
Attach Arduino Mega to RAMPS shield.
If you need data storage use SD card shield (maybe boot load from it).
If you want an interface attach an LCD or touch screen shield.
These are all parts often used to build RepRap printers.
When used as a printer you can tether the printer with USB (emulated serial) or use a SD card to standalone.
The Arduino provides the USB connection and the SD card shield is obviously for the SD card.
Program the Arduino yourself instead of using a G/M code interpreter that would usually read the G/M code from the card when this is used to be a RepRap printer control.
The platform is still Arduino underneath.
http://www.makergeeks.com/a4stmodrmo.html
http://reprap.org/wiki/Arduino_Mega_Pololu_Shield
http://reprap.org/wiki/RAMPS_1.4 - Test code at the bottom.
Please be aware that the test code uses the Arduino digitalwrite function which is fast enough but there are faster ways to toggle Arduino pins.
