Go to Post Like many researchers before me, I look and read about what my peers are doing and developing, and then incorperate the best of them into my ideas or change my focus because of them. - Wetzel [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 20-10-2014, 01:05
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Rookie Year: 2011
Flimsor will become famous soon enough
2015 Game Hint!
At the Washington Girl's Generation event this past weekend, Blair Hundtermark made a surprise visit. He talked to the audience, and revealed that the 2015 game is in the bag, and media for it is currently being filmed. He also gave the following game hint:
"Think big, be big."
It's very uncommon for FIRST to put out a game hint this early, so it's legitimacy isn't completely certain. Seeing as it was at a PNW event, it could be region specific, but no one will know for sure until kickoff.
So, theories?
I think it would be awesome if this means the robots will have to join together to make one big robot, like in the Voltron anime, but of course that's almost impossible, and I'm kidding
Note: this isn't meant to be taken seriously, and is just a way to spark up conversation for the 2015 game as a way to pass the time.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Last edited by Flimsor : 20-10-2014 at 02:05. Reason: Edited to clarify that hint may not be valid; additional note added.
Unread 20-10-2014, 01:08
Andrew Lawrence
Posts: n/a
Re: 2015 Game Hint!
Would they give a hint to only a select group of people? No.
Not a game hint.
Unread 20-10-2014, 01:14
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: 2015 Game Hint!
Sounds like generic advice for being successful in any of FRC's prior 23 games, in any engineering challenge, and in life.
Not something meaningful details of the game can be derived from in the slightest (not that "official" game hints are any different).
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 20-10-2014, 01:33
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: 2015 Game Hint!
Blair also revealed a game hint one year at Championship involving three colored lights.
It had no bearing on the next year's game.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 20-10-2014, 01:40
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Re: 2015 Game Hint!
To be completely fair, this could probably be said for a majority of official game hints.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 20-10-2014, 02:19
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: 2015 Game Hint!
If it's labeled as "Official XXXX Game Hint #Y", it usually does have some bearing. It just never shows as obvious until Kickoff that year.
Past teams:
Unread 20-10-2014, 03:08
AKA: Eli Barnett
Re: 2015 Game Hint!
For a very loose definition of "bearing." IIRC, the game hint for Lunacy was a picture of a fish (admittedly it was a "moon fish," but still...).
Unread 20-10-2014, 04:03
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
Re: 2015 Game Hint!
The thing is, for a game hint to be of actual use, fully solving it without any further context must provide tangible insight into how the "solution" could actually manifest itself in the game, or at the very least, steer your pre-kickoff thoughts in a relevantly focused direction. With this in mind, lets look at some solutions to recent game hints:
2014: Assists. Gives us a part of the game name, and the nebulous idea that passing will be useful. Nothing to suggest how this will be put in practice, nothing to suggest big balls, launching, 2008 throwback, etc. As a designer, no benefit.
2013: Reference to a pyramid, disks, and using weight to calculate score. Quite a stretch to go from "pyramid" to "climb this weird pipe structure sequentially with very specific rules". Same with disks, there are a lot of disk objects that could have been used. And what on earth were we supposed to learn about gameplay by knowing that weight would be used for measuring something? As a designer, very marginal benefit requiring lucky guesses.
2012: High speed counters, rapid real time scoring. An element of several very different games before and after 2012. No information whatsoever to point to balls, shooting, or bridges. As a designer, no benefit.
2011: Locomotion + Logo = Logomotion, to a lesser extent, pillar --> minibot pole. No way to determine the minibot task, or even the very concept of minibots. No way to determine the name of the game will be implemented through inner tubes on pegs. As a designer, no benefit.
2010: If I recall, someone actually did reverse engineer the CAD drawing to estimate a gamepiece roughly the diameter of a soccer ball. Soccer-esque rules had to be pulled from thin air, as 2002 showed that soccer balls as a gamepiece didn't necessarily mean kicking mechanisms. And the extra gate nebulously suggested field obstruction, leading to thoughts about rough terrain drives. Absolutely nothing to suggest hanging. As a designer, very marginal benefit from the gate, potentially more benefit from the soccer ball.
2009: Moonfish. Without any more information, very hard to jump from this to a simulation of reduced gravity. Nothing to suggest mass ball game, or the funky design of the Moonrocks. As a designer, no benefit.
For the past 6 years, there has been very little to gain from the game hints even if they are fully solved, and absolutely nothing of value from four of the six when you consider what you can learn from them without the benefit of hindsight. This is why I, and most people who have been around for a while, just filter out the inevitable 500+ post thread each year, and don't expend effort searching for these unofficial "hints," much less trying to solve them.
Unread 20-10-2014, 08:42
RunawayEngineer RunawayEngineer is offline
Master Commander of All Things Tech
AKA: Ches
FRC #0801 (Horsepower)
Team Role: Tactician
RunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to beholdRunawayEngineer is a splendid one to behold
Re: 2015 Game Hint!
I think all the hysteria over game hints is inherited from a few hints that actually had the possibility to be revealing.
For instance, 2007's game hint:
actually shows a possible configuration of game piece on its scoring target. It is not obvious by any means, but it was observed as a possibility.
Hints like this spurred on the idea that if you looked hard enough, you would get something advantageous.
However, I have never heard of a team that actually used a game hint - official or otherwise - to even attempt to gain a head start.
Unread 20-10-2014, 09:36
Derpancakes's Avatar
Derpancakes Derpancakes is offline
Student Leader
FRC #2838 (Eaglebots)
Team Role: Mechanical
Rookie Year: 2007
Derpancakes has a little shameless behaviour in the past
Re: 2015 Game Hint!
Guys, it's space. So many space-related events are happening in 2015, and 'think big'? (Insert Wheatley quote here)
Obsession with modifying electronics? Check.
Obsession with retro video games and music? Check.
Obsession with synths? Check.
Obsession with FIRST? Check.
"Doctor, we've got a borderline nerd. The only thing that could make it worse is...."
Obsession with Doctor Who? Check.
"Oh God, it's more serious than I could have imagined!"
Unread 20-10-2014, 09:42
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: 2015 Game Hint!
SPAAAAAAAAAACE!
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 20-10-2014, 10:07
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Re: 2015 Game Hint!
What could be bigger than 2' exercise ball? Can it be shot or pushed it into crescent shaped goal?
Unread 20-10-2014, 10:16
therobo-titan's Avatar
therobo-titan therobo-titan is offline
The Scout that Keeps on Scouting
AKA: Schuyler
FRC #5332 (Toaster Tech)
Rookie Year: 2010
therobo-titan is an unknown quantity at this point
Re: 2015 Game Hint!
"Think big, be big". So it would have to be something big that when you become part of it, you become as big as it is. When you put an extra drop of water into the ocean, it becomes indistinguishable from the rest of the water, and thus can be as big as the entire body. It can only mean one thing:
WATER GAME CONFIRMED!
Unread 20-10-2014, 10:17
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Rookie Year: 2011
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Re: 2015 Game Hint!
Big, the ocean is ~72% of the world, which to me, is relatively big. Water game
  #15   Spotlight this post!
Unread 20-10-2014, 21:13
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: 2015 Game Hint!
How about a 3.5' exercise ball, from 2008? Same construction and everything, just bigger.
Past teams:
