Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
Unread 25-10-2014, 14:45
FTC25 FTC25 is offline
FTC #0025
FTC25 is an unknown quantity at this point
Exclamation Legality of 2.5 Gallon Water Jugs
Are 2.5 Gallon Water Jugs legal? We are planning to use the bottom half as a container to hold balls on our robot.
Unread 25-10-2014, 15:30
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Legality of 2.5 Gallon Water Jugs
Assuming you're building a robot for a 2014 off-season event then I see no reason as to why a 2.5 gallon water jug wouldn't be legal. Just make sure it fits completely inside the frame perimeter and isn't sharp and you should be fine.
Edit: I didn't read your user name before commenting Sorry about that!
Unread 25-10-2014, 15:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Based upon Game Manual Part 1, <R04><b> it would appear that yes, this is legal.
http://www3.usfirst.org/sites/defaul...ual_Part_I.pdf
You should Q&A it though, as I haven't done FTC since 2010.
Unread 25-10-2014, 15:49
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Since you appear to be asking about FTC material utilization, I looked in the FTC manual. Keeping in mind that I've never competed in FTC, it looks like this would be a COTS post-processed material with 0 degrees of freedom (since it has no joints or hinges inherently), which would be allowed under R04 parts B and C, if it was obtained from a standard distributor and would be considered obtainable by the majority of teams.
Unread 25-10-2014, 16:58
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I am guessing that the applicable rule is R04
b. All post-processed materials are allowed provided they are readily available to the majority of teams from standard distributers (e.g. McMaster-Carr, Home Depot, AndyMark, etc.).
Examples of allowable post processed materials are:
perforated sheet and diamond plate
Injection molded parts
3D printed parts
I am guessing the part in question is an injection molded part.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 26-10-2014, 20:32
Briansmithtown's Avatar
Briansmithtown Briansmithtown is offline
Pilot shortage, Good thing Im tall
AKA: Brian Sheridan
FRC #0810 (Smithtown Mechanical Bulls)
Briansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond repute
Just don't put water in it... Or do! (Surprise watergame!)
2014 Team 810 Recap video https://www.youtube.com/watch?v=DS9K_j1FzF4
