Go to Post "I need the adjustable hammer" "You mean that wren-" "No, it's a hammer" - Karibou [more]
Unread 26-10-2014, 12:57
speckz speckz is offline
FTC #8910
speckz is an unknown quantity at this point
Logitech USB Controller Programming Issues
We cannot get our Logitech USB controllers to work properly with our code in RobotC. The debugger picks up when buttons are pressed and joysticks are moved correctly but when the code is run the code will not pick up what is going on with the controller.
Here is the code:
Code:
#pragma config(Hubs,  S1, MatrxRbtcs, none,     none,     none)
#pragma config(Sensor, S1,     ,               sensorI2CMuxController)
#pragma config(Motor,  mtr_Matrix_S1_1, motorD,        tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_Matrix_S1_2, motorE,        tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_Matrix_S1_3, motorF,        tmotorMatrix, openLoop)
#pragma config(Motor,  mtr_Matrix_S1_4, motorG,        tmotorMatrix, openLoop)
#pragma config(Servo,  srvo_Matrix_S1_1, servo1,               tServoNone)
#pragma config(Servo,  srvo_Matrix_S1_2, servo2,               tServoNone)
#pragma config(Servo,  srvo_Matrix_S1_3, servo3,               tServoNone)
#pragma config(Servo,  srvo_Matrix_S1_4, servo4,               tServoNone)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
#include "JoystickDriver.c"
task main()
  servo[servo1] = -127;
  wait1Msec(500);
  while (true)
  	getJoystickSettings(joystick);
  	if(joy1Btn(00) == true)
  		servo[servo1] = 127
This is a matrix robot for the First Tech Challenge. Moving motors and servos normally works fine but when we try to do it with a USB controller the code does not pick anything up.
We are using NXT brick which has the correct firmware from RobotC 4.26.
What might we be doing wrong? Thank you.
Unread 26-10-2014, 17:09
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Logitech USB Controller Programming Issues
Code:
task main()
  wait1Msec(500);
  while (true)
  		servo[servo1] = 127;
Try this and see if you can figure out what I changed.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 29-10-2014, 15:44
FTC #8910
Originally Posted by Wiifi View Post
Code:
task main()
  wait1Msec(500);
  while (true)
Yes I realize I missed a semicolon but that's not the problem it still doesn't work. I know my code is right I'm positive it's something with the setup but find nothing wrong with the setup.
