Go to Post (Respecting a decision) != (Agreeing with it) - dtengineering [more]
Unread 26-10-2014, 22:24
wward2906 wward2906 is offline
FRC #2906
wward2906 is an unknown quantity at this point
[FTC]: Getting wireless to run on FTC bot
We have been using Blue Tooth to test and drive our bot. However the BT has gone down on the computer. We have a netgear N600 duel band router (WNDR3400). Are our attempts to try and get the bot to hook up to this router been in vane? We are having no success using the FTC how to... Supportive suggestions needed.
Unread 26-10-2014, 22:48
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: [FTC]: Getting wireless to run on FTC bot
Have you taken a look at this?
http://www.usfirst.org/sites/default..._for_Teams.pdf
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-11-2014, 18:57
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
This is the link to a guide on how to connect the Samantha Module to the wifi.
http://www.robotc.net/wiki/TETRIX_Samantha_Module
This is the link to a guide on how to connect the laptop to the robot once you have connected the Samantha Module to the wifi.
http://cdn.robotc.net/pdfs/competiti...i%20ROBOTC.pdf
The Samantha Module should be able to connect to any wifi.
Hope that helps.
-The Charging Champions
https://www.facebook.com/chargingchampions
Unread 30-11-2014, 19:36
ftelliott ftelliott is offline
Sunset High School Head Coach
AKA: Friedrich Elliott
FTC #8811 (RoBo Bison)
Team Role: Coach
Rookie Year: 2013
ftelliott is an unknown quantity at this point
I believe the Samantha Module only connects to wifi devices that support the 802.11b protocol.
Unread 02-12-2014, 12:07
Team 6955 Team 6955 is offline
FTC #6955
Team 6955 is an unknown quantity at this point
The netgear N600 duel band router should work.
The first thing you will need to do is go into the settings of the router and disable the 5.0GHz (and make sure the 2.4GHz is activated) name the network something easy (ours is FTC_6955).
Next set the security to open (so there is no password needed to connect, it makes thing easier).
Finally create your setup flash-drive and "Flash" your samantha using the instructions HERE
