Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 27-10-2014, 22:29
jimmers205 jimmers205 is offline
jimmers205 is an unknown quantity at this point
Need general drive train expertise
Hey everyone, I'm a rookie member of a team doing research.
On this product's page (http://www.wcproducts.net/wcp-shifter-3cim/), what does it mean by motor pinion select? I see the 11T, etc. down below in the gear ratio charts, but what's the difference between 11Tx2 and 11Tx3?
Also, more general questions:
How do different shifters work?
How does the pneumatics work with the gearbox?
What is spread ratio? Each different spread ratio looks like it has similar overlaps in FPS.
Thanks!
